How to use .AppImage on Manjaro (Arch based Linux)?
What would you recommend to do to use .AppImage apps on Manjaro?
I read recommended to install folllowing app:
sudo pacman -S appimagelauncher
Then i doubleclicked the appimage and i was invited to define save path and it added the start menu shortcut and created /home/me/.config/ files.
Do you have other way to handle this or things to note?
Other than reading more about AppImages and AppImageLauncher, that’s it.
