Hello everyone this my first post in this community <3!
So far I’ve been enjoying the manjaro i3 flavor but had one question in my mind, How do i remove shadows under the i3status bar? (Screenshot attached)
I searched few places and found that it has something to do with compton? I tried making a config with a single line
According to the man page of picom (man picom) the -C or --no-dock-shadow option is deprecated and the suggestion is to use the wintypes option instead.
In your ~/.config/picom.conf file you can add this
wintypes :
dock :
shadow = false;
in order to disable shadows in all windows with window type “dock”.
Another option would be to create a new rule in the shadow-exclude option of picom in your ~/.config/picom.conf file, in order to disable shadows for the i3bar only:
