UNIX was designed from the ground up as a multi-user operating system, while Microsoft Windows was designed as a graphical user interface with cooperative multitasking for an inherently single-user operating system, i.e. MS-DOS.
The concept of multi-user terminal servers didn’t even exist yet in Windows NT until Citrix modified the NT 4.0 kernel for their Citrix WinFrame product, and then Microsoft bought the rights to that kernel hack from them and sold it as Windows NT 4.0 Terminal Server.
It doesn’t. Manjaro does not develop Plasma. We import the Plasma packages directly from Arch, and Arch itself builds those packages from the upstream source code, which is developed by kde.org.
I know It’s not a funny one . Learned a lot, thanks.
Yes, indeed. Thanks.
It works for me, while the issue mentioned persists, but I know it’s not related to the OS. thanks for your clarification.
I was doing:
using ctrl + alt + F3 to switch to tty3 (when ctrl + alt + F1 pressed, these is only a flashing cursor, can’t input anything. Current user is on ctrl + alt + F2, tty2)
login the second user
start KDE plasma with startx -- :1
BTW, the speaker of my laptop looks get exclusively occupied by the second user. The first user could use it until I login it out.
Yes, this is due to how sddm works in combination with systemd. sddm will commonly claim either tty1 or tty2, so the first available free tty will be tty3.
Note that this will start Plasma on X11. If you prefer Wayland, then you should use startplasma-wayland.
Yes, but this is a limitation of the hardware. The local console is not multiplexed, and the audio hardware is therefore given ownership to the active user account logged in at the local console.
This is to be expected, since the pulseaudio or pipewire service is started as a user service for the first user that logs in. If you want to run it as a system service or allow other users to use a already started audio service you need to configure this.
Not 100% sure if it’s the same issue, but: Sometimes when I’m switching users (KDE Plasma start menu → leave → switch user → end up in sddm → enter credentials → enter) my screen goes black as well. I have to ‘search’ for the correct tty via ctrl + alt + f1/2/3/…). Kind of a weird behavior but besides that everything works fine related to having multiple users logged in at the same time.
