There is one interesting thing called xxhash that I want to switch. Linux Kernel 5.3+ supports it. I know Fedora supports xxhash for BTRFS.
I tried to add xxhash in MODULES in the config file /etc/mkinitcpio.conf.
Then sudo mkinitcpio -P linux, then reboot.
But the checksum algorithm is not changed , still using crc32c.
I think I should give up, because many old checksum results were already stored in many existing metadata when I use the filesystem long.
You should not change the checksum algorithm in Kernel for BTRFS, otherwise many old metadata could go wrong.
I would assume BTRFS behaves in the same way as ZFS. Each block contains a pointer/reference its stored-state attributes, such as compression algorithm, compression-level, checksum algorithm, etc.
Therefor, existing blocks should not be affected. They will continue to use the same checksum to verify their integrity. Newly written blocks, however, will use the new checksum (if you apply such a change.)
I am confused by this “kernel” checksum vs. BTRFS checksum, however. Aren’t they two separate things?
Before I would have thought that if BTRFS reads the parameter “checksum” from Kernel config before installation and then set the defined checksum in BTRFS config, that was my guess. There is no clear document about that.
I would not think this is the behavior. It wouldn’t be appropriate (or even make sense.)
For example, in ZFS, the “checksum” property is defined with ZFS commands. It has nothing to do with the kernel, nor even matter if you use FreeBSD, Linux, or whatever.
I would assume the same thing applies to BTRFS.
I’m not as familiar with BTRFS, but here’s an example of viewing and changing the checksum property for a ZFS dataset. (I edited some of the text to make it less confusing.)
Query the current value:
zfs get checksum myPool/backups/photos
NAME PROPERTY VALUE
myPool/backups/photos checksum fletcher4
Set the new value:
zfs set checksum=sha512 myPool/backups/photos
Query the new value:
NAME PROPERTY VALUE
myPool/backups/photos checksum sha512
There’s likely a BTRFS method of doing the same thing as above.
UPDATE: The terminology is different. A ZFS “dataset” is similar to a BTRFS “subvolume”.
Looks like BTRFS doesn’t currently support changing the checksum for existing filesystems. You must define it a the time of creation!
For example, mkfs.btrfs --csum xxhash
Apparently, the BTRFS developers didn’t use foresight to deal with different digest sizes. So basically it’s a “hard lock” on the checksum you use at the time of creating a new BTRFS filesystem.
ZFS developers, however, thought ahead, and thus you can easily change the checksum at any time, as many times as you desire, even with different digest sizes.
This again illustrates how ZFS is more matured and flexible. I’m serious when I say that we’d all be using ZFS instead of BTRFS if there was no legal issues and it was part of mainline kernel development.
EDIT: We replied at the same time. I explained above why this is not possible with BTRFS, sadly.
If it means anything, @Zesko, you’re using the “hardware accelerated” method. If you were not, it would instead read: crc32c-generic
The word “intel” can be misleading. It’s still supported by modern AMD CPUs. It might use the word “intel” because the Intel company was the first to introduce and develop it.
Think about “AES-NI hardware acceleration” for encryption. It was originally developed by Intel, yet it is fully supported by AMD CPUs as well.
