How to switch microcode?
Hi!
Have ordered CPU/Motherboard to switch from Intel platform to AMD one (Ryzen 7). What is an appropriate moment to uninstal intel-ucode and isntall amd-ucode?
I don’t see any conflicts in the packages’ descriptions, so is it safe to install both? Or is some sequence of (un)installation/hardware-replacement is needed?
Right before switching the CPU would be the best time.
Make sure to run sudo update grub after installing amd-ucode and uninstalling intel-ucode.
AFAIK there is no risk to have both (or none) installed. Microcode will only apply to the relevant brand available.
Next time, first use a search engine of your choice, answers are easily available in the wiki:
https://wiki.archlinux.org/title/Microcode
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
