How to switch from x11 to wayland?
echo $XDG_SESSION_TYPE
x11
On XFCE?
You dont.
Or rather … you dont with XFWM.
If you want to replace your window manager with a wayland capable one it may be possible … if you also replace the Display Manager … but IDK.
https://wiki.archlinux.org/title/Wayland
You mean it is not necessary in xfce, why?
How do I know if I’m using GDM or Lightdm?
I finally did not understand if xfce supports wayland or not?
I can switch, if I do, there will be a problem
all those questions are answered in the linked archwiki article
https://docs.xfce.org/xfce/libxfce4windowing/start
As far as I understand, it is not fully supported at the moment
