Hello there,
Im somehow struggeling to swap to the g++ compiler. How do i do this?
(base) [eisbergsalat@eisbergsalat-pc ~]$ which c++
/usr/bin/c++
(base) [eisbergsalat@eisbergsalat-pc ~]$ which g++
/usr/bin/g++
(base) [eisbergsalat@eisbergsalat-pc ~]$ which gcc
/usr/bin/gcc
i get the following warning in python/pytorch that why i wann ahave a g++
Your compiler (c++) is not compatible with the compiler Pytorch was
built with for this platform, which is g++ on linux. Please
use g++ to to compile your extension. Alternatively, you may
compile PyTorch from source using c++, and then you can also use
c++ to compile your extension.
