How to stop virtual desktop change by mouse scrolling
I cannot find a way to disable that feature. Is there an option somewhere ??
TX
Your explanations are a bit thin, I hope I’ve made sense of them.
Go to
  • settings - xfwm4-tweaks-settings - workspaces
  • uncheck mousewheel to change workspaces
Otherwise, make sure you focus the thing that you wish to scroll – before you touch the mouse wheel.
Or, if you don’t intend scrolling anything, focus the desktop itself (click). This is simply behaviour that might help avoid it.
To disable it completely, follow the advice given by @banjo
[Solved] Disable "switch windows using the mouse wheel" / Desktop / Xfce Forums
xfconf-query -c xfwm4 -p /general/scroll_workspaces -s false
