unable to satisfy dependency ‘pygtk’ required by fslint-gui"
OK, pygtk seems to be some python 2 dinosaur, and i can go ahead and find some other duplicate file finder, but how do I stop pamac from trying to install pygtk when I attempt to install other software?
This is only true to some extent. Pacman can actually see and remove a AUR package without any problem unless the package is installed manually that is with makepkg or something.
I suspect the same. What is the output of pacman -Qs fslint-gui?
Cool, glad you both settled it …
I’ll be honest, since sudo pacman -S <AUR-package>
always ends with Error: target not found for me was no point to try sudo pacman -R <AUR-package> ever.
