How to stop notifs and how to make spam go to its folder on Evolution?
i use evolution email client on gnome…
what is the way to stop getting notifications from the evolution application?
i get a lot of spam…
also, how do you make the spam to go to the spam folder and not to the inbox?
i use custom domains… and i use another app on android for accessing the same inboxes…
tnx
I’m sure Evolution allows to create message filters;
somehow…
Apparently there are plugins that handle spam filtering;
Thunderbird user here, but these might also be helpful:
seems like i’ve evolution-bogofilter installed already but it only flags it as spam most of the time… it doesn’t move it to the spam folder…
i’m using imap…
i will try to search for “notifications gnome” for knowing how to turn off notifications…
tnx
edit… here is a screenshot of it…
So you can setup a custom filter to move all flagged messages to the Spam folder…
did it. tnx
was a bit complicated but i figured it out
i guess i need to do it on the android device too… true?
Probably since I don’t think it was server-side.
