i am new to manjaro so forgive me if i miss something.i bought a Aux microphone because the internal microphone is broken but whenever i plug in the microphone manjaro changes speaker port to headphones.thinking i plugged in a headphone . so every time i need to change the port
to speakers .so how do i prevent manjaro from changing speaker ports every time i plug in a microphone
have a look in pavucontrol
I have tried pavucontrol ,The ports keep changing to headphones when i unplug and plug the microphone back in or when i restart . Alsa mixer dont work either
is pipewire installed ?
pacman -Qs pipewire
yes pipewire is installed
local/pipewire 1:0.3.34-1
Low-latency audio/video router and processor
local/pipewire-media-session 1:0.3.34-1
Low-latency audio/video router and processor - Session manager
Some one please help me
I know nothing of pipewire, but lets look to see if you are running pulseaudio and pipewire
execute
inxi -Axxx
alsa can automute current output device on detection of another output device.
execute each line of command in turn.
alsamixer # likely to show only pulseadio or maybe pipewire so...
alsamixer -c0
alsamixer -c1
alsa count devices by zero, 1,2,etc not from 1.
Even if you have only one device, alsa calls it a card
Press repeatedly → to navigate to the automute section.
If its on press up or down to disable
similar to this image
Trivia for most laptops, hdmi is card 0 and analog is card 1
Laptop jack socket has an auto-mute function in ALSA. The auto-mute only detects if a jack is plugged in and cannot tell what device is connected via the jack
One way to deal with the auto-mute is to reconfigure the jack and disable the headphone connection so it only supports an external microphone
Install package alsa-tools
and run the retasking tool with root privileges
sudo hdajackretask
Find the Pin ID for Headphone ; enable the Override and select Not Connected from the drop-down list
Click Install Boot Override
Reboot system to load the override
output of inxi -Axxx
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
Sound Server-1: ALSA v: k5.14.0-0-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
auto-mute is disabled in alsa mixer
but when i plug and unplug my mic it still mutes my speakers
with mic plugged in
without mic plugged in
sudo alsactl store and dont work
how to install alsa-tools
i cant find it
try alsa-utils
you hae both pipewire and pulseaudio running at once. Choose one not both
Pamac GUI usually shows the package as different hardware tools:
- Echomixer (alsa-tools)
- Envy24 (alsa-tools)
- HDSPConf (alsa-tools)
- HDSPMixer (alsa-tools)
or install from terminal
pamac install alsa-tools
System data is showing 2 incompatible sound servers running
Pipewire cannot support audio unless PulseAudio is removed and replaced, but it will impede PulseAudio function
Use this command to stop, disable and mask Pipewire service and socket
systemctl --user disable --now pipewire.{socket,service} && systemctl --user mask pipewire.socket
sudo hdajackretask
Fixed my problem
