Is this from Manjaro Settings icon ? If so I’m not seeing a power option.
I only have options for Locale Settings, Language Packages, Kernel, User Accounts, Time and Date, Keyboard Settings and Hardware Configuration.
Not seeing that option, I think something must have gone wrong with the initial install ?
I only see
Manjaro Settings…
LightDM GTK+…
KDE Connect Settings…
Print Settings…
AppImageLaunch…
Manjaro Notifier…
So you installed Gnome after another DE and you are using the same user for all?
Might get into some issues on the way, but … probably you can manage
The solution goes to @freggel.doe
Not that I’m aware of - probably unintentional.
I really wanted XFCE but Gnome was installed instead, maybe I chose the wrong image to install I can’t remember.
I may scrub completely and install XFCE . My home folder is on another partition,sda6, so this should be unaffected if I wipe my Manjaro partition sda7 ?
If you will install the system on another partition yes, will not affect your home, but always keep in mind that some configurations from a different DE, kept in your home might interfere with configurations from new DE install.
Yes, but for instance if you keep in ~/.config/autostart/ something from another DE, or specific to it, might get funky. GTK+ settings are a bit different too between Gnome and XFCE or KDE.
.xinitrc file is different also …
Please do that. It will save everyone time and less headaches all around. Start fresh, pay attention this time and don’t start randomly installing different DE’s without realizing you don’t even have Settings.
I don’t like your attitude.
For your information I do not install DEs randomly, I think that through one of the upgrades something must have gone wrong.
I’m trying a fresh install of 20.1-rc6 Mikah onto a new disk and I can’t even get that to work!
New query launched.
