How to know which systems are safe to mask and not?
systemd-analyze
Startup finished in 6.250s (firmware) + 2.629s (loader) + 3.873s (kernel) + 22.577s (userspace) = 35.330s
graphical.target reached after 20.938s in userspace
systemd-analyze blame
9.214s systemd-journal-flush.service
4.913s udisks2.service
4.826s dev-sda2.device
3.028s polkit.service
2.716s dev-loop2.device
2.704s apparmor.service
2.293s cups.service
2.210s modprobe@drm.service
2.138s dev-loop0.device
2.114s upower.service
2.036s dev-loop3.device
2.009s systemd-random-seed.service
1.759s dev-loop1.device
1.758s systemd-fsck@dev-disk-by\x2duuid-3DC6\x2dA581.service
1.662s systemd-udevd.service
1.651s systemd-sysctl.service
1.636s tlp.service
1.415s NetworkManager.service
1.228s user@1000.service
1.069s avahi-daemon.service
764ms systemd-rfkill.service
systemd-analyze critical-chain
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @20.938s
ββmulti-user.target @20.937s
ββModemManager.service @20.295s +641ms
ββpolkit.service @17.264s +3.028s
ββbasic.target @17.249s
ββsockets.target @17.249s
ββdbus.socket @17.249s
ββsysinit.target @17.180s
ββsystemd-timesyncd.service @17.041s +138ms
ββsystemd-tmpfiles-setup.service @16.681s +268ms
ββsystemd-journal-flush.service @7.466s +9.214s
ββsystemd-journald.service @7.331s +133ms
ββhaveged.service @7.329s
ββsystemd-tmpfiles-setup-dev.service @6.988s +338ms
ββkmod-static-nodes.service @6.782s +135ms
ββsystemd-journald.socket @6.673s
ββsystem.slice @6.575s
ββ-.slice @6.575s
inxi -Fxz
System: Kernel: 5.14.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.22.5
Machine: Type: Laptop System: Acer product: Aspire A514-53 v: V1.16 serial: <filter>
Mobo: IL model: Sneezy_IL v: V1.16 serial: <filter> UEFI: Insyde v: 1.16 date: 01/18/2021
Battery: ID-1: BAT0 charge: 32.5 Wh (98.5%) condition: 33.0/53.0 Wh (62.3%) volts: 16.7 min: 15.4
model: PANASONIC KT004 AP19B5L status: Charging
CPU: Info: Dual Core model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake rev: 5 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 9524
Speed: 1008 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 1008 2: 1053 3: 1085 4: 1051
Graphics: Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI driver: i915 v: kernel bus-ID: 00:02.0
Device-2: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 1-6:3
Display: x11 server: X.Org 1.20.13 driver: loaded: modesetting resolution: 1366x768~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 21.2.1 direct render: Yes
Audio: Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.14.2-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.35 running: yes
Network: Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel port: 4000 bus-ID: 00:14.3
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI driver: r8169
v: kernel port: 3000 bus-ID: 01:00.0
IF: enp1s0 state: down mac: <filter>
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-10:4
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: N/A rfk-block: hardware: no software: yes
address: see --recommends
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 bus-ID: 00:17.0
Device-1: md126 type: mdraid level: N/A status: inactive size: N/A
Info: report: N/A blocks: 2136 chunk-size: N/A
Components: Online: N/A Spare: 0: nvme0n1
Device-2: md127 type: mdraid level: N/A status: inactive size: N/A
Info: report: N/A blocks: 2944 chunk-size: N/A
Components: Online: N/A Spare: 0: nvme1n1
Drives: Local Storage: total: 1.4 TiB used: 32.21 GiB (2.2%)
ID-1: /dev/nvme0n1 vendor: Intel model: HBRPEKNX0202A size: 476.94 GiB temp: 28.9 C
ID-2: /dev/nvme1n1 vendor: Intel model: HBRPEKNX0202AO size: 27.25 GiB temp: 34.9 C
ID-3: /dev/sda vendor: Seagate model: ST1000LM048-2E7172 size: 931.51 GiB
Partition: ID-1: / size: 392.65 GiB used: 32.21 GiB (8.2%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 511 MiB used: 308 KiB (0.1%) fs: vfat dev: /dev/sda4
Swap: ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) dev: /dev/sda3
Sensors: System Temperatures: cpu: 50.0 C mobo: N/A
Info: Processes: 188 Uptime: 5m Memory: 7.45 GiB used: 2.16 GiB (29.0%) Init: systemd Compilers: gcc: 11.1.0
Packages: 1287 Shell: Zsh v: 5.8 inxi: 3.3.06
neofetch
ββββββββββββββββββ ββββββββ soumi@Hori
ββββββββββββββββββ ββββββββ ----------
ββββββββββββββββββ ββββββββ OS: Manjaro Linux x86_64
ββββββββββββββββββ ββββββββ Host: Aspire A514-53 V1.16
ββββββββ ββββββββ Kernel: 5.14.2-1-MANJARO
ββββββββ ββββββββ ββββββββ Uptime: 6 mins
ββββββββ ββββββββ ββββββββ Packages: 1287 (pacman)
ββββββββ ββββββββ ββββββββ Shell: bash 5.1.8
ββββββββ ββββββββ ββββββββ Resolution: 1366x768
ββββββββ ββββββββ ββββββββ DE: Plasma 5.22.5
ββββββββ ββββββββ ββββββββ WM: KWin
ββββββββ ββββββββ ββββββββ Theme: Breeze Light [Plasma], Breeze [GTK2/3]
ββββββββ ββββββββ ββββββββ Icons: breeze [Plasma], breeze [GTK2/3]
ββββββββ ββββββββ ββββββββ Terminal: konsole
CPU: Intel i3-1005G1 (4) @ 3.400GHz
GPU: Intel Iris Plus Graphics G1
Memory: 2004MiB / 7630MiB
