Hi all, I’'m newbie in manjaro.
How to shrink manjaro image? I tried the usual way (with GPT fix) but didn’t want to turn it on.
I shrink image with fdisk (remove second partition and create new, little bit smaller), and then fix the GPT with gdisk, and look good:
Disk /dev/sda: 7.4 GiB, 7910457344 bytes, 15450112 sectors
Disk model: SDDR-399
Disklabel type: gpt
Disk identifier: BAF0ADF7-CCE3-4FEB-B083-B81373F698DE
Device Start End Sectors Size Type
/dev/sda1 62500 500000 437501 213.6M Microsoft basic data
/dev/sda2 500001 15039224 14539224 7G Linux filesystem
(In microSD card reader connected the other rockpi, thats why shows sda not mmcblk)
It seems to boot, signal on hdmi, boot messages appear (no error), then black, no ethernet.
There is a continuous signal on HDMI, but only black.
What have I done wrong?
Update: PARTUUID is match (blkid = extlinux.conf), parted, fdisk, gdisk, e2fsck is ok.
Update2: All boot steps running, last line: “Starting kernel…” and black screen.
Thank you!
