In pacman -Syu
outputs a list of packages just show total size update
I want show size for each package.
How to get the download size for each package?
I don’t think you can with pacman
The only related commands that i know of, as a noob in pacman/pamac are:
pamac info
packagename -
pacman -Qi
packagename
Which are essentially the same, but only show the installed size, not the size of the package that needs to-be DL’ed because those are compressed…
Maybe someone has/can make a script to query the mirrors for the package and interpret the HTTP response they get back
But show size pacman -Syu
for each size in distro endeavoros
You have to use -Si
Then switch to endeavoros or copy their code.
Are you sure it shows the DOWNLOAD size and not the installed size?
AHA !
Yes, now we get download size…super !
Maybe remove the comment on the following line in /etc/pacman.conf
#VerbosePkgLists
From pacman.conf(5)
VerbosePkgLists
Displays name, version and size of target packages formatted as a table for upgrade, sync and remove operations.
@Manji, See the answer before yours by @NGr …
Make sure to thank them by marking their reply as the solution
Edit: Darn he already deleted his reply
@TriMoon Both of our messages were posted at the same time, so I deleted them
Don’t be quick to judge
