I installed LAMP and anything is working. How I like to get a list with Apache modules.
The Debian/Ubuntu command “apache2ctl” I used before will not work in Manjaro.
After I research, I found that the setting file should be in /etc/httpd/conf/httpd.conf
but in my installation is called “/etc/apache2/apache2.conf”
What is correct? An and how can I get the Apache module list?
The configuration for Apache Http Server is in /etc/httpd/ for Manjaro and other Arch based Distributions. There is no /etc/apache2/ . If you have a /etc/apache2/ folder check if it is owned by a package.
Of course, if you want you can configure httpd to use /etc/apache2/, but this is something you will need to do on your own.
You can use httpd -M or apachectl -t -D DUMP_MODULES to check which modules are loaded.
