server ❯ sudo nvim /etc/fstab
/run/media/user/R /srv/nfs/R none bind 0 0
server ❯ sudo mount -a
mount: (hint) your fstab has been modified, but systemd still uses
the old version; use 'systemctl daemon-reload' to reload.
server ❯ sudo nvim /etc/exports
/srv/nfs 192.168.1.0/24(rw,sync,crossmnt,fsid=0)
/srv/nfs/R 192.168.1.0/24(rw,sync)
server ❯ sudo systemctl enable --now nfs-server.service
client ❯ sudo nvim /etc/systemd/system/data-nfs-R.mount
[Unit]
Description=R
After=network.target
[Mount]
What=192.168.1.122:/nfs/R
Where=/data/nfs/R
Type=nfs
Options=_netdev,auto
[Install]
WantedBy=multi-user.target
client ❯ sudo systemctl enable data-nfs-R.mount
client ❯ sudo nvim /etc/systemd/system/data-nfs-R.automount
[Unit]
Description=Automount R drive share
ConditionPathExists=/data/nfs/R
[Automount]
Where=/data/nfs/R
TimeoutIdleSec=10
[Install]
client ❯ sudo systemctl enable --now data-nfs-R.automount
client ❯ cd /data/nfs
cd: no such file or directory: /data/nfs
# See UUID in gnome-disk-utility
server ❯ sudo nvim /etc/systemd/system/data-nfs-R.mount
[Unit]
Description=My shared partition
[Mount]
What=/dev/disk/by-uuid/8066D52E66D525A6
Where=/data/nfs/R
Type=ntfs
Options=defaults,rw,noatime
[Install]
server ❯ sudo systemctl enable --now data-nfs-R.mount
Created symlink /etc/systemd/system/multi-user.target.wants/data-nfs-R.mount → /etc/systemd/system/data-nfs-R.mount.
Job failed. See "journalctl -xe" for details.
server ❯ journalctl -xe
Support: https://forum.manjaro.org/c/support
░░ An n/a= process belonging to unit data-nfs-R.mount has exited.
░░ The process' exit code is 'exited' and its exit status is 16.
jul 16 14:19:59 arch systemd[1]: data-nfs-R.mount: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ Defined-By: systemd
░░ The unit data-nfs-R.mount has entered the 'failed' state with result 'exit-code'.
jul 16 14:19:59 arch systemd[1]: Failed to mount My shared partition.
░░ Subject: A start job for unit data-nfs-R.mount has failed
░░ A start job for unit data-nfs-R.mount has finished with a failure.
░░ The job identifier is 2550 and the job result is failed.
jul 16 14:19:59 arch audit[3276547]: USER_END pid=3276547 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session>
jul 16 14:19:59 arch audit[3276547]: CRED_DISP pid=3276547 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcre>
jul 16 14:19:59 arch sudo[3276547]: pam_unix(sudo:session): session closed for user root
jul 16 14:20:01 arch syncthing[1321]: [H4RSE] INFO: Puller (folder "home" (lgu5e-zpytn), item ".mozilla/firefox/5k3mpg4>
jul 16 14:20:01 arch syncthing[1321]: [H4RSE] INFO: "home" (lgu5e-zpytn): Failed to sync 1 items
jul 16 14:20:01 arch syncthing[1321]: [H4RSE] INFO: Folder "home" (lgu5e-zpytn) isn't making sync progress - retrying i>
jul 16 14:20:31 arch syncthing[1321]: [H4RSE] INFO: Puller (folder "home" (lgu5e-zpytn), item ".mozilla/firefox/5k3mpg4>
jul 16 14:20:31 arch syncthing[1321]: [H4RSE] INFO: "home" (lgu5e-zpytn): Failed to sync 1 items
jul 16 14:20:31 arch syncthing[1321]: [H4RSE] INFO: Folder "home" (lgu5e-zpytn) isn't making sync progress - retrying i
… don’t use the /run/...
folder but another dedicated folder as in the example
/run
and it’s contents are special as in they do not exist permanently
I’m trying to share the content of a hard drive. How would I do it then?
Mount the device in /data/nfs/R using the mount unit
You don’t use automount on server for a service shares - only on clients.
/run is a volatile structure recreated on boot - don’t use.
Create a share point in /srv/nfs/R
Bind /data/nfs/R to /srv/nfs/R in fstab- doing so ensures your are not exposing your real file system to computers accessing the service.
Reload fstab
sudo mount -a
differently?
start with not using the /run directory to mount your drive
The drive has a device name (/dev/sdXx
That device needs to be mounted to (e.g)
/srv/nfs/R
make sure it is mounted before you try to share it via NFS
run is where the hard drive is mounted by default. How do I make the hard drive mount automatically somewhere else? I don’t want to mount it manually every time.
Assuming this is the system running the nfs server service
You need the partition UUID - replace the yX with the device letter and partition number e.g. sda1
lsblk -no UUID /dev/sdyX
Then in your mount unit /etc/systemd/system/data-nfs-R.mount - (replace $UUID below with the result of above command)
[Unit]
[Mount]
What=/dev/disk/by-uuid/$UUID
Where=/data/nfs/R
Type=ext4
[Install]
enable and start the unit
on your server
sudo mkdir -p /srv/nfs/R
In your server’s fstab
/data/nfs/R /srv/nfs/R none bind 0 0
I had assumed the mounting was done in the client from reading the tutorial. All this is in the server then?
sharing the device is server
consuming the share is client
both are configured differently - and the guide describes both
- the mounting and sharing is described
https://forum.manjaro.org/t/root-tip-share-data-using-nfs/29667#the-share-3 - the client consumption is described
https://forum.manjaro.org/t/root-tip-share-data-using-nfs/29667#client-10
[Unit]
[Mount]
Where=/data/nfs/R
Type=ntfs
[Install]
Make sure you have no colliding mounts from previous attempts.
If the mount point is populated subsequent mounts will fail
this needs to end in the actual UUID of your device - not in “$UUID”
I don’t know how to do that. How can I remove the previous /data/nfs/R
mount?
I know, I’ve substituted it when pasting it here.
sudo umount /dev/sdxY
So I have to unmount the hard drive or the created mount point? Would it be sudo umount /data/nfs/R
You can do that
I just tested to verify
[fh@tiger ~]$ sudo micro /etc/systemd/system/a-ntfs.mount
[fh@tiger ~]$ cat /etc/systemd/system/a-ntfs.mount
[Unit]
Description=ntfs test mount
[Mount]
What=/dev/disk/by-uuid/3A572DCB04BC70C8
Where=/a/ntfs
Type=ntfs
[Install]
[fh@tiger ~]$ sudo systemctl start a-ntfs.mount
[fh@tiger ~]$ systemctl status a-ntfs.mount
● a-ntfs.mount - ntfs test mount
Loaded: loaded (/etc/systemd/system/a-ntfs.mount; disabled; preset: disabled)
Active: active (mounted) since Sat 2022-07-16 14:39:07 CEST; 6s ago
Until: Sat 2022-07-16 14:39:07 CEST; 6s ago
Where: /a/ntfs
What: /dev/sde1
Tasks: 1 (limit: 76998)
Memory: 684.0K
CPU: 5ms
CGroup: /system.slice/a-ntfs.mount
└─43943 /usr/bin/mount.ntfs /dev/sde1 /a/ntfs -o rw,noatime
Jul 16 14:39:07 tiger systemd[1]: Mounting ntfs test mount...
Jul 16 14:39:07 tiger ntfs-3g[43943]: Version 2022.5.17 external FUSE 29
Jul 16 14:39:07 tiger ntfs-3g[43943]: Mounted /dev/sde1 (Read-Write, label "", NTFS 3.1)
Jul 16 14:39:07 tiger ntfs-3g[43943]: Cmdline options: rw,noatime
Jul 16 14:39:07 tiger ntfs-3g[43943]: Mount options: allow_other,nonempty,noatime,rw,fsname=/dev/sde1,blkdev,>
Jul 16 14:39:07 tiger ntfs-3g[43943]: Ownership and permissions disabled, configuration type 7
Jul 16 14:39:07 tiger systemd[1]: Mounted ntfs test mount.
[fh@tiger ~]$ mount | grep ntfs
/dev/sde1 on /a/ntfs type fuseblk (rw,nosuid,nodev,noatime,user_id=0,group_id=0,allow_other,blksize=4096)
[fh@tiger ~]$ ls /a/ntfs/
[fh@tiger ~]$ touch /a/ntfs/test.file
test.file
I’ll restart and try again later because it isn’t mounting for some reason
server ❯ sudo mv /etc/systemd/system/data-nfs-R.mount /etc/systemd/system/r-ntfs.mount
server ❯ lsblk -no UUID /dev/sde1
8066D52E66D525A6
server ❯ sudo cat /etc/systemd/system/r-ntfs.mount
[Unit]
[Mount]
Where=/r/ntfs
Type=ntfs
[Install]
server ❯ sudo systemctl start r-ntfs.mount
Failed to start r-ntfs.mount: Unit r-ntfs.mount has a bad unit file setting.
See system logs and 'systemctl status r-ntfs.mount' for details.
server ❯ systemctl status r-ntfs.mount
× r-ntfs.mount - My shared partition
Loaded: loaded (/etc/systemd/system/r-ntfs.mount; disabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Sat 2022-07-16 14:50:32 CEST; 4min 26s ago
Where: /r/ntfs
What: /dev/disk/by-uuid/8066D52E66D525A6
CPU: 4ms
jul 16 14:50:32 arch systemd[1]: Mounting My shared partition...
jul 16 14:50:32 arch mount[157246]: Mount is denied because the NTFS volume is already exclusively opened.
jul 16 14:50:32 arch mount[157246]: The volume may be already mounted, or another software may use it which
jul 16 14:50:32 arch mount[157246]: could be identified for example by the help of the 'fuser' command.
jul 16 14:50:32 arch systemd[1]: r-ntfs.mount: Mount process exited, code=exited, status=16/n/a
jul 16 14:50:32 arch systemd[1]: r-ntfs.mount: Failed with result 'exit-code'.
jul 16 14:50:32 arch systemd[1]: Failed to mount My shared partition.
░░ Subject: Unit process exited
░░ An n/a= process belonging to unit r-ntfs.mount has exited.
░░ The unit r-ntfs.mount has entered the 'failed' state with result 'exit-code'.
░░ Subject: A start job for unit r-ntfs.mount has failed
░░ A start job for unit r-ntfs.mount has finished with a failure.
░░ The job identifier is 2576 and the job result is failed.
jul 16 14:50:32 arch sudo[157230]: pam_unix(sudo:session): session closed for user root
jul 16 14:50:32 arch audit[157230]: USER_END pid=157230 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_c>
jul 16 14:50:32 arch audit[157230]: CRED_DISP pid=157230 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred >
jul 16 14:50:32 arch kernel: audit: type=1106 audit(1657975832.587:430): pid=157230 uid=1000 auid=1000 ses=1 subj==unco>
jul 16 14:50:32 arch kernel: audit: type=1104 audit(1657975832.587:431): pid=157230 uid=1000 auid=1000 ses=1 subj==unco
The number one rule
mount point and mount unit name must match
You cannot use my example letter to letter.
You must uses you own UUID and you must use your path matching the unit name
mount point the Where → /data/nfs/R
unit name → data-nfs-R.mount
My bad I fixed the error message.
