Hello there
I wrote my own zsh
config based on the manjaro-zsh-config
, but two forms of autocompletion don’t work:
yay -S soft [tab-tab]
No autocompletion that searches for software -
find - [tab-tab]
Flags aren’t autocompleted with double tabbing
I would like to know what is missing from my config, thanks:
# My zsh configurations (Based on the Manjaro ZSH config)
## Print basmalah:
COLUMNS=$(tput cols)
basmalah="--- بسم الله الرحمن الرحيم ---"
printf "%*s\n" $(((${#title}+$COLUMNS)/1.5)) "$basmalah"
## Setopt section
setopt interactivecomments
setopt correct
setopt extendedglob
setopt nocaseglob
setopt rcexpandparam
setopt nocheckjobs
setopt numericglobsort
setopt nobeep
setopt appendhistory
setopt histignorealldups
setopt autocd
setopt inc_append_history
setopt histignorespace
compctl -M '' 'm:{a-zA-Z}={A-Za-z}'
zstyle ':completion:*' matcher-list 'm:{a-zA-Z}={A-Za-z}'
zstyle ':completion:*' list-colors "${(s.:.)LS_COLORS}"
zstyle ':completion:*' rehash true
zstyle ':completion:*' accept-exact '*(N)'
zstyle ':completion:*' use-cache on
zstyle ':completion:*' cache-path ~/.zsh/cache
## Variables section
HISTFILE=~/.zhistory
HISTSIZE=10000
SAVEHIST=10000
WORDCHARS=${WORDCHARS//\/[&.;]}
ks=/home/abdullah/Software/01-VM/KALI_VM_SHARE
wificard=wlp2s0
p10k_path=/usr/share/zsh-theme-powerlevel10k/powerlevel10k.zsh-theme
autosuggestions_path=/usr/share/zsh/plugins/zsh-autosuggestions/zsh-autosuggestions.zsh
highlighting_path=/usr/share/zsh/plugins/zsh-syntax-highlighting/zsh-syntax-highlighting.zsh
substring_path=/usr/share/zsh/plugins/zsh-history-substring-search/zsh-history-substring-search.zsh
p10k_config_path="$(dirname $(realpath $0))/yf-p10k.zsh"
## Plugins section: Enable fish style features
# Use the powerlevel10k theme
source $p10k_path
# Command history autosuggestions
source $autosuggestions_path
# Use syntax highlighting
source $highlighting_path
# Use history substring search
source $substring_path
# bind UP and DOWN arrow keys to history substring search
zmodload zsh/terminfo
bindkey "$terminfo[kcuu1]" history-substring-search-up
bindkey "$terminfo[kcud1]" history-substring-search-down
bindkey '^[[A' history-substring-search-up
bindkey '^[[B' history-substring-search-down
## Keybindings section
bindkey -e
bindkey '^[[7~' beginning-of-line # Home key
bindkey '^[[H' beginning-of-line # Home key
if [[ "${terminfo[khome]}" != "" ]]; then
bindkey "${terminfo[khome]}" beginning-of-line # [Home] - Go to beginning of line
fi
bindkey '^[[8~' end-of-line # End key
bindkey '^[[F' end-of-line # End key
if [[ "${terminfo[kend]}" != "" ]]; then
bindkey "${terminfo[kend]}" end-of-line # [End] - Go to end of line
fi
bindkey '^[[2~' overwrite-mode # Insert key
bindkey '^[[3~' delete-char # Delete key
bindkey '^[[C' forward-char # Right key
bindkey '^[[D' backward-char # Left key
bindkey '^[[5~' history-beginning-search-backward # Page up key
bindkey '^[[6~' history-beginning-search-forward # Page down key
bindkey '^[Oc' forward-word #
bindkey '^[Od' backward-word #
bindkey '^[[1;5D' backward-word #
bindkey '^[[1;5C' forward-word #
bindkey '^H' backward-kill-word # delete previous word with ctrl+backspace
bindkey '^[[Z' undo # Shift+tab undo last action
# Color man pages
export LESS_TERMCAP_mb=$'\E[01;32m'
export LESS_TERMCAP_md=$'\E[01;32m'
export LESS_TERMCAP_me=$'\E[0m'
export LESS_TERMCAP_se=$'\E[0m'
export LESS_TERMCAP_so=$'\E[01;47;34m'
export LESS_TERMCAP_ue=$'\E[0m'
export LESS_TERMCAP_us=$'\E[01;36m'
export LESS=-R
## Function section
colours()
for i in {0..255}
do
print -Pn "%K{$i} %k%F{$i}${(l:3::0:)i}%f " ${${(M)$((i%6)):#3}:+$'\n'}
done
## Syntax highlighting (Taken from Kali Linux setup) & my custom P10K theme config
# Color man pages
export LESS=-R
source $p10k_config_path
if [ -f /usr/share/zsh/plugins/zsh-syntax-highlighting/zsh-syntax-highlighting.zsh ]; then
ZSH_HIGHLIGHT_HIGHLIGHTERS=(main brackets pattern)
ZSH_HIGHLIGHT_STYLES[default]=none
ZSH_HIGHLIGHT_STYLES[unknown-token]=fg=red,bold
ZSH_HIGHLIGHT_STYLES[reserved-word]=fg=cyan,bold
ZSH_HIGHLIGHT_STYLES[suffix-alias]=fg=green,underline
ZSH_HIGHLIGHT_STYLES[global-alias]=fg=magenta
ZSH_HIGHLIGHT_STYLES[precommand]=fg=green,underline
ZSH_HIGHLIGHT_STYLES[commandseparator]=fg=blue,bold
ZSH_HIGHLIGHT_STYLES[autodirectory]=fg=green,underline
ZSH_HIGHLIGHT_STYLES[path]=underline
ZSH_HIGHLIGHT_STYLES[path_pathseparator]=
ZSH_HIGHLIGHT_STYLES[path_prefix_pathseparator]=
ZSH_HIGHLIGHT_STYLES[globbing]=fg=blue,bold
ZSH_HIGHLIGHT_STYLES[history-expansion]=fg=blue,bold
ZSH_HIGHLIGHT_STYLES[command-substitution]=none
ZSH_HIGHLIGHT_STYLES[command-substitution-delimiter]=fg=magenta
ZSH_HIGHLIGHT_STYLES[process-substitution]=none
ZSH_HIGHLIGHT_STYLES[process-substitution-delimiter]=fg=magenta
ZSH_HIGHLIGHT_STYLES[single-hyphen-option]=fg=magenta
ZSH_HIGHLIGHT_STYLES[double-hyphen-option]=fg=magenta
ZSH_HIGHLIGHT_STYLES[back-quoted-argument]=none
ZSH_HIGHLIGHT_STYLES[back-quoted-argument-delimiter]=fg=blue,bold
ZSH_HIGHLIGHT_STYLES[single-quoted-argument]=fg=yellow
ZSH_HIGHLIGHT_STYLES[double-quoted-argument]=fg=yellow
ZSH_HIGHLIGHT_STYLES[dollar-quoted-argument]=fg=yellow
ZSH_HIGHLIGHT_STYLES[rc-quote]=fg=magenta
ZSH_HIGHLIGHT_STYLES[dollar-double-quoted-argument]=fg=magenta,bold
ZSH_HIGHLIGHT_STYLES[back-double-quoted-argument]=fg=magenta,bold
ZSH_HIGHLIGHT_STYLES[back-dollar-quoted-argument]=fg=magenta,bold
ZSH_HIGHLIGHT_STYLES[assign]=none
ZSH_HIGHLIGHT_STYLES[redirection]=fg=blue,bold
ZSH_HIGHLIGHT_STYLES[comment]=fg=black,bold
ZSH_HIGHLIGHT_STYLES[named-fd]=none
ZSH_HIGHLIGHT_STYLES[numeric-fd]=none
ZSH_HIGHLIGHT_STYLES[arg0]=fg=green
ZSH_HIGHLIGHT_STYLES[bracket-error]=fg=red,bold
ZSH_HIGHLIGHT_STYLES[bracket-level-1]=fg=blue,bold
ZSH_HIGHLIGHT_STYLES[bracket-level-2]=fg=green,bold
ZSH_HIGHLIGHT_STYLES[bracket-level-3]=fg=magenta,bold
ZSH_HIGHLIGHT_STYLES[bracket-level-4]=fg=yellow,bold
ZSH_HIGHLIGHT_STYLES[bracket-level-5]=fg=cyan,bold
ZSH_HIGHLIGHT_STYLES[cursor-matchingbracket]=standout
fi
EDIT: it works fine using the default manjaro-zsh-config
