I reinstalled Manjaro Gnome recently and went for the minimal ISO instead of the full install. Read around the forums to download and install ffmpegthumbnailer but I still can’t see thumbnails. It once tried to do so but only a few where made and tinted green but I did a reinstall of ffmpegthumbnailer with sudo pacman -S ffmpegthumbnailer and nothing yet, any ideas?
Hi @Raik,
Do you have totem movie player installed?
If not, install it and see if it helps:
pamac install totem
If you do, then check for failed entries in
~/.cache/thumbnails/fail/gnome-thumbnail-factory/
…and if there are, delete the fail
folder.
Hope this helps!
Reference:
In my videos, thumbnails are only made for locally stored files. Not those in cloud or network storage. So that may be a factor.
And it is also adjustable:
- from which file extensions thumbs are created
- whether only local files are taken into account
- the maximum size of the files
Thanks a lot for the help. @Mirdarthos indeed, deleting the fail folder made it refresh. Thanks for everything and have a great day ya’ll
