How to set-up shell autocomplete?
How do i set-up shell auto complete? Is there a step-by-step tutorial available?
My shell is: bash. I have installed bash-completion. I have a script to install.
Where do i install the script to make this work?
[john@johnPC ~]$ which $SHELL
/bin/bash
System :
[john@johnPC ~]$ inxi -zv8
  Kernel: 6.6.47-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=006e2571-c404-468d-b0e3-99124c0e2644 rw quiet splash apparmor=1
    security=apparmor resume=UUID=d7c4842e-f940-460f-9adf-3e788d0c882d
    udev.log_priority=3
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Desktop System: Micro-Star product: MS-7C87 v: 1.0
    serial: <superuser required>
  Mobo: Micro-Star model: B450M BAZOOKA MAX WIFI (MS-7C87) v: 1.0
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: 1.90 date: 05/24/2022
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K360
    status: discharging
  Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master 2S
    status: discharging
  System RAM: total: 32 GiB available: 27.29 GiB used: 3.25 GiB (11.9%)
    (unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Micron Technology part-no: 16ATF1G64AZ-2G1B1
    serial: <filter>
    serial: <filter>
  Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
    serial: <filter>
    serial: <filter>
  Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
    microcode: 0xA50000D
    desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 400 min/max: 400/4464 scaling: driver: amd-pstate-epp
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 93456
    xsaves
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
    Radeon Mobile Series] driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1
    empty: HDMI-A-2,HDMI-A-3 bus-ID: 30:00.0 chip-ID: 1002:1638 class-ID: 0300
    temp: 27.0 C
  Device-2: HDR webcam driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 1d6c:0103
    class-ID: 0102
  Display: x11 server: X.org v: 1.21.1.13 compositor: xfwm4 v: 4.18.0
    driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung C32F39M
    serial: <filter> built: 2019 res: 1920x1080 hz: 60 dpi: 70 gamma: 1.2
    chroma: red: x: 0.647 y: 0.337 green: x: 0.325 y: 0.616 blue: x: 0.145
    y: 0.055 white: x: 0.314 y: 0.329 size: 698x393mm (27.48x15.47")
    diag: 801mm (31.5") ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900,
    1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.6-arch1.1
    renoir LLVM 18.1.8 DRM 3.54 6.6.47-1-MANJARO) device-ID: 1002:1638
    memory: 3.91 GiB unified: no
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
    Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.1
    chip-ID: 1002:1637 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  Device-3: HDR webcam driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
    class-ID: 0102
  API: ALSA v: k6.6.47-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 21:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 22:00.0
    chip-ID: 8086:24fb class-ID: 0280
  IF: wlp34s0 state: up mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  IF-ID-2: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
    mac: <filter>
  IP v6: <filter> type: noprefixroute scope: global
  IF-ID-3: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  Info: services: NetworkManager,wpa_supplicant
  Device-1: Intel Wireless-AC 3168 Bluetooth driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 8087:0aa7
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.2
    lmp-v: 8 status: discoverable: yes pairing: yes class-ID: 7c0104
  Local Storage: total: 2.12 TiB used: 165.72 GiB (7.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Silicon Power
    model: SPCC M.2 PCIe SSD size: 476.94 GiB block-size: physical: 512 B
    fw-rev: V0523B0 temp: 34.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD3200AVJS-63B6A0 size: 298.09 GiB block-size: physical: 512 B
    logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 3A02
    scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST31000528AS
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC38 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: ST500LM012 HN-M500MBB
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 0003 scheme: GPT
  ID-1: / raw-size: 467.84 GiB size: 459.43 GiB (98.20%)
    used: 165.72 GiB (36.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 006e2571-c404-468d-b0e3-99124c0e2644
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 5924-F7F7
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: d7c4842e-f940-460f-9adf-3e788d0c882d
  ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
    uuid: 8ED7-2DA2
  ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: ntfs label: h
    uuid: 0FDF0C850FDF0C85
  ID-3: /dev/sda3 maj-min: 8:3 size: 80.92 GiB fs: ntfs label: Boot Disc
    uuid: 1612D8A212D887DF
  ID-4: /dev/sda4 maj-min: 8:4 size: 216.57 GiB fs: ext4 label: John_223
    uuid: 05c0fa63-faa2-4aa3-a13b-b6f35b52868d
  ID-5: /dev/sda5 maj-min: 8:5 size: 499 MiB fs: ext4 label: N/A
    uuid: 4a5f8f45-6f05-4c57-92ee-4703e22823d9
  ID-6: /dev/sdb1 maj-min: 8:17 size: 95.45 GiB fs: ext4 label: John_102
    uuid: 18c9ee3c-9d73-4262-96d8-05cb367223bf
  ID-7: /dev/sdb3 maj-min: 8:19 size: 836.06 GiB fs: ext4 label: John_828
    uuid: 9681ad2e-bbc3-4490-8f16-2bcc73e8cdc0
  ID-8: /dev/sdc1 maj-min: 8:33 size: 465.76 GiB fs: ext4 label: John_500
    uuid: fd1f35e4-77ef-4787-9efa-861696a65bfb
  Device-1: 1-4:2 info: HDR webcam type: video,audio
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 4mA
    chip-ID: 1d6c:0103 class-ID: 0102
  Device-2: 1-5:3 info: Intel Wireless-AC 3168 Bluetooth type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0aa7 class-ID: e001
  Hub-2: 1-8:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-8.2:6 info: Logitech Unifying Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-8.3:7 info: Alcor Micro 8-in-1 Media Card Reader
    type: mass storage driver: usb-storage interfaces: 1 rev: 1.1
    chip-ID: 058f:9360 class-ID: 0806 serial: <filter>
  Device-3: 1-9:5 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c87 class-ID: 0300
    serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-7: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 32.4 C mobo: N/A gpu: amdgpu temp: 27.0 C
  Fan Speeds (rpm): N/A
  Packages: 1822 pm: dpkg pkgs: 0 pm: pacman pkgs: 1781 libs: 404
    tools: pamac,yay pm: flatpak pkgs: 25 pm: snap pkgs: 16
    1: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    7: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 337
  1: cpu: 8.5% command: firefox pid: 3248 mem: 572.9 MiB (2.0%)
  2: cpu: 5.0% command: firefox pid: 10850 mem: 287.9 MiB (1.0%)
  3: cpu: 2.5% command: xfce4-terminal pid: 12023 mem: 46.6 MiB (0.1%)
  4: cpu: 2.3% command: Xorg pid: 1307 mem: 169.5 MiB (0.6%)
  5: cpu: 0.8% command: firefox pid: 10892 mem: 226.0 MiB (0.8%)
  Memory top: 5 of 337
  1: mem: 572.9 MiB (2.0%) command: firefox pid: 3248 cpu: 8.5%
  2: mem: 456.9 MiB (1.6%) command: protonvpn-app started-by: python
    pid: 2092 cpu: 0.5%
  3: mem: 287.9 MiB (1.0%) command: firefox pid: 10850 cpu: 5.0%
  4: mem: 226.0 MiB (0.8%) command: firefox pid: 10892 cpu: 0.8%
  5: mem: 208.5 MiB (0.7%) command: firefox pid: 10591 cpu: 0.7%
  Processes: 337 Power: uptime: 53m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 10.9 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: 256 default: graphical tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Bash v: 5.2.32
    running-in: xfce4-terminal inxi: 3.3.36
[john@johnPC ~]$
The script:
# Bash completion definition for buku.
# Author:
#   Arun Prakash Jana <engineerarun@gmail.com>
_buku () {
    COMPREPLY=()
    local IFS=$' \n'
    local cur=$2 prev=$3
    local -a opts opts_with_args
    opts=(
        -a --add
        --ai
        -c --comment
        --cached
        --colors
        -d --delete
        --deep
        -e --export
        --expand
        -f --format
        -h --help
        -i --import
        --immutable
        -j --json
        -k --unlock
        -l --lock
        -n --count
        --nc
        --np
        -o --open
        --oa
        -p --print
        -r --sreg
        --replace
        -s --sany
        -S --sall
        --url-redirect
        --tag-redirect
        --tag-error
        --del-error
        --export-on
        --shorten
        --offline
        --suggest
        -t --stag
        --tacit
        --tag
        --threads
        --title
        -u --update
        --url
        -V
        -v --version
        -w --write
        -x --exclude
        -g --debug
    opts_with_arg=(
        -a --add
        --cached
        --colors
        -e --export
        --expand
        -f --format
        -i --import
        --immutable
        -n --count
        -r --sreg
        --replace
        -s --sany
        -S --sall
        --shorten
        --threads
        --url
        -x --exclude
    # Do not complete non option names
    [[ $cur == -* ]] || return 1
    # Do not complete when the previous arg is an option expecting an argument
    for opt in "${opts_with_arg[@]}"; do
        [[ $opt == $prev ]] && return 1
    done
    # Complete option names
    COMPREPLY=( $(compgen -W "${opts[*]}" -- "$cur") )
    return 0
complete -F _buku buku
Where does the script come from?
They should have some idea on how to integrate it with existing bash-completion?
I see you have installed the package bash-completion already.
Further hints can be found here:
https://wiki.archlinux.org/title/Bash#Bash_history_completion
There exists also a tab completion feature (which is enabled by default):
How did you install buku? If installed via the AUR, the PKGBUILD appears to take care of bash auto-completion for you.
package() {
  install -Dm644 auto-completion/fish/buku.fish "$pkgdir/usr/share/fish/vendor_completions.d/buku.fish"
  install -Dm644 auto-completion/bash/buku-completion.bash "$pkgdir/usr/share/bash-completion/completions/buku"
man bash
