I’m using Manjaro i3wm. I have cups installed. Any way I can set the default printer to “Print to File” in LibreOffice?
I found the following in the below link. Perhaps it’s useful.
Mine didn’t disappear. It’s always there. I just want it to be selected by default.
@jrichard326
I saw that. It’s only the settings for printer and print to file, not for selecting which one should be default.
If the above doesn’t work, then you have to set the default printer virtually via CUPS.
