Hi everybody.
First of all, thanks for any help i may get here. I’m still quite new to working with Manjaro, although i have used Debian on my PC for a while.
Now to my issue: I need to set a default GPU for my PC, because I want to go a GPU passthrough. I currently have 2 GPUs in my PC, a AMD Radeon RX 5700 (will be my guest GPU) and a NVIDEA GeForce GT 710 (will be my host GPU).
My Mainboard (MSI B450 Tomahawk Max) has one PCI x16 3.0 slot (used for the AMD GPU) and the NVIDEA GPU is in a x16 2.0 slot.
I have spend a long time searching in the BIOS for the default gpu setting, but I have been unable to find it. I would greatly appreciate it if anyone could either tell me where to switch the default GPU in BIOS or where to set it somewhere else.
