Is their some way in order to change the default application volume from 100% to 20% in pipewire so I don’t blow my ears out every time?
inxi --admin --verbosity=7 --filter --width
Kernel: 5.17.15-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=45eb26c1-85ca-4d97-9940-cbcd7ff04e49 rw quiet apparmor=1
security=apparmor resume=UUID=16fa4317-a427-4a14-9b40-e625866bc2b6
udev.log_priority=3
Console: pty pts/2 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Desktop System: Micro-Star product: MS-7C56 v: 1.0 serial: N/A
Mobo: Micro-Star model: MPG B550 GAMING PLUS (MS-7C56) v: 1.0
serial: <filter> UEFI: American Megatrends LLC. v: 1.83 date: 09/24/2021
Device-1: hidpp_battery_0
model: Logitech Marathon Mouse/Performance Plus M705 serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: discharging
RAM: total: 15.55 GiB used: 6.49 GiB (41.8%)
Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 3000 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: N/A
part-no: CL16-18-18 D4-3000 serial: N/A
Device-2: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-3: DIMM 0 type: no module installed
Device-4: DIMM 1 type: no module installed
Info: model: AMD Ryzen 5 3600 socket: AM4 bits: 64 type: MT MCP arch: Zen 2
gen: 3 built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2316 high: 3600 min/max: 2200/4208 boost: enabled
base/boost: 3600/4200 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3600 2: 2200 3: 2200 4: 2200
5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
bogomips: 86427
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: ZOTAC driver: nvidia
v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 2b:00.0
chip-ID: 10de:1f82 class-ID: 0300
Device-2: WCM_USB WEB CAM type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-1:2 chip-ID: 1c3f:2002 class-ID: 0102
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 101 s-size: 1449x272mm (57.05x10.71")
s-diag: 1474mm (58.04")
Monitor-1: DP-1 pos: center res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
Monitor-2: DVI-D-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 92
size: 531x299mm (20.91x11.77") diag: 609mm (23.99") modes: N/A
Monitor-3: HDMI-0 pos: right res: 1920x1080 hz: 75 dpi: 102
size: 480x270mm (18.9x10.63") diag: 551mm (21.68") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 515.48.07 direct render: Yes
Device-1: NVIDIA vendor: ZOTAC driver: snd_hda_intel v: kernel bus-ID: 3-1:2
pcie: chip-ID: 1c3f:2002 gen: 3 class-ID: 0102 speed: 8 GT/s lanes: 16
bus-ID: 2b:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: WCM_USB WEB CAM type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.17.15-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.1 running: no
Sound Server-4: PipeWire v: 0.3.52 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 2a:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
driver: N/A bus-ID: 1-2.1:4 chip-ID: 0bda:8179 class-ID: 0000
serial: <filter>
driver: btusb v: 0.8 bus-ID: 1-2.2:5 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 2.15 TiB used: 835.84 GiB (37.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
family: BarraCuda 3.5 (SMR) size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: 0001 temp: 36 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 4274h+05m+47.562s cycles: 60
read: 2.95 TiB written: 2.56 TiB Pre-Fail: attribute: Spin_Retry_Count
value: 100 worst: 100 threshold: 97
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
family: Driven SSDs size: 223.57 GiB block-size: physical: 512 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 0102 temp: 42 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 152d 14h cycles: 433
read: 13334 GiB written: 16843 GiB
ID-3: /dev/sdg maj-min: 8:96 type: USB vendor: Generic model: N/A
size: 119.15 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.11 scheme: MBR
Optical-1: /dev/sr0 vendor: hp model: DVD A DH16ACSH rev: JHD6
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 206.1 GiB size: 201.81 GiB (97.92%)
used: 85.57 GiB (42.4%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18 label: N/A uuid: 45eb26c1-85ca-4d97-9940-cbcd7ff04e49
used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
label: NO_LABEL uuid: C94C-480D
ID-3: /run/media/gcars06/0123-4567 raw-size: 119.13 GiB
size: 119.13 GiB (100.00%) used: 145.1 MiB (0.1%) fs: exfat
block-size: 4096 B dev: /dev/sdg1 maj-min: 8:97 label: N/A uuid: 0123-4567
ID-4: /run/media/gcars06/New_Media raw-size: 1.8 TiB
size: 1.77 TiB (98.37%) used: 750.12 GiB (41.4%) fs: ext4 block-size: 4096 B
dev: /dev/sda3 maj-min: 8:3 label: New_Media
uuid: f1d7ed3c-4439-4a30-a35f-d809a1ba1552
ID-1: swap-1 type: partition size: 17.17 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb3 maj-min: 8:19 label: swap
uuid: 16fa4317-a427-4a14-9b40-e625866bc2b6
ID-1: /dev/sda1 maj-min: 8:1 size: 512 MiB fs: vfat label: N/A
uuid: E756-EC94
ID-2: /dev/sda2 maj-min: 8:2 size: 512 MiB fs: vfat label: N/A
uuid: E756-EC94
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-2.1:4
info: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: WiFi
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 0bda:8179 class-ID: 0000 serial: <filter>
Device-2: 1-2.2:5
info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: Bluetooth
Device-3: 1-2.4:7 info: Alcor Micro Flash Card Reader/Writer
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 058f:6362 class-ID: 0806
serial: <filter>
Device-4: 1-5:10 info: Microsoft Xbox Wireless Controller (model 1914)
type: <vendor specific> driver: xpad interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 045e:0b12 class-ID: ff00 serial: <filter>
Device-5: 1-6:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-6: 1-7:6 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7c56 class-ID: 0300 serial: <filter>
Hub-3: 1-10:8 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Device-1: 1-10.1:9 info: GEMBIRD MicroSD Card Reader/Writer
speed: 480 Mb/s power: 150mA chip-ID: 1908:0226 class-ID: 0806
Hub-4: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: WCM_USB WEB CAM type: Video,Audio
power: 100mA chip-ID: 1c3f:2002 class-ID: 0102
Device-2: 3-3:3 info: Holtek Gaming keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 04d9:a1cd class-ID: 0300
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 39 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 50%
Processes: 368 Uptime: 5h 23m wakeups: 28 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: 1452 pacman: 1443 lib: 401 flatpak: 6 snap: 3 Shell: Zsh (sudo)
v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.19
