How to set a default kernel?
Iam having two kernals 5.13 and 5.4 LTS and I want set kernel 5.4 as default kernal.
I have tried to select the kernel 5.4 LTS on the grub when booting and it booted into kernel 5.4 but on next startup it automatically booted into 5.13
I have to manually switch to kernal 5.4, but I want to boot into kernel 5.4 as default.
It’s because My dgpu works fine on kernel 5.4 LTS only.
System info:
System:    Kernel: 5.13.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
           parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.13-x86_64 root=UUID=25ef3aaf-fb0a-4b8d-a4e3-27c0c1dd2336 rw
           rootflags=subvol=@ quiet apparmor=1 security=apparmor udev.log_priority=3 radeon.si_support=0 radeon.cik_support=0
           amdgpu.si_support=1 amdgpu.cik_support=1
           Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine:   Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A serial: <filter> Chassis: type: 9 serial: <filter>
           Mobo: Dell model: 0D53F5 v: A00 serial: <filter> UEFI: Dell v: 2.15.0 date: 06/16/2021
Battery:   ID-1: BAT0 charge: 24.5 Wh (67.7%) condition: 36.2/41.4 Wh (87.3%) volts: 15.2 min: 14.8
           model: LGC-LGC2.80 DELL 7PY0D0A type: Li-ion serial: <filter> status: Discharging
CPU:       Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake note: check family: 6
           model-id: 8E (142) stepping: 9 microcode: EA cache: L2: 3 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21607
           Speed: 800 MHz min/max: 400/2500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
           Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics:  Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5916
           class-ID: 0300
           Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520 Mobile] vendor: Dell driver: amdgpu
           v: kernel alternate: radeon bus-ID: 01:00.0 chip-ID: 1002:6660 class-ID: 0380
           Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-5:3 chip-ID: 0bda:5769 class-ID: 0e02
           serial: <filter>
           Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati,modesetting
           alternate: fbdev,vesa display-ID: :0 screens: 1
           Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0") s-diag: 414mm (16.3")
           Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
           OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.1 direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel v: kernel alternate: snd_soc_skl
           bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
           Sound Server-1: ALSA v: k5.13.12-1-MANJARO running: yes
           Sound Server-4: PipeWire v: 0.3.33 running: yes
Network:   Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: e000 bus-ID: 02:00.0 chip-ID: 8086:3165
           class-ID: 0280
           Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169 v: kernel port: d000
           bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-8:5 chip-ID: 8087:0a2a
           class-ID: e001
           Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
           address: see --recommends
Drives:    Local Storage: total: 931.51 GiB used: 174.87 GiB (18.8%)
           ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB block-size: physical: 4096 B
           logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: SDM3 scheme: GPT
Partition: ID-1: / raw-size: 100.1 GiB size: 100.1 GiB (100.00%) used: 9.63 GiB (9.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
           ID-2: /boot/efi raw-size: 200.2 MiB size: 197.1 MiB (98.45%) used: 554 KiB (0.3%) fs: vfat dev: /dev/sda4
           maj-min: 8:4
           ID-3: /home raw-size: 828.19 GiB size: 828.19 GiB (100.00%) used: 165.24 GiB (20.0%) fs: btrfs dev: /dev/sda2
           maj-min: 8:2
           ID-4: /var/log raw-size: 100.1 GiB size: 100.1 GiB (100.00%) used: 9.63 GiB (9.6%) fs: btrfs dev: /dev/sda1
           maj-min: 8:1
Swap:      Alert: No swap data was found.
Sensors:   System Temperatures: cpu: 44.0 C mobo: 42.0 C
           Fan Speeds (RPM): cpu: 0
Info:      Processes: 224 Uptime: 1h 8m wakeups: 2 Memory: 7.64 GiB used: 2.13 GiB (27.8%) Init: systemd v: 248
           tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1254 lib: 356 flatpak: 0 Shell: Bash v: 5.1.8
           running-in: konsole inxi: 3.3.06
If you only want to use 5.4, you could delete the others.
Otherwise, this forum has a search function which will reveal this thread: How to make a Kernel default? - #3 by linux-aarhus
To get relevant search results, “kernel” needs to spelled correctly.
A little bit more of explication there to understand how is it under the hood :
https://wiki.archlinux.org/title/GRUB/Tips_and_tricks#Recall_previous_entry
This is not your case according to your system infos, but this works only if /boot is NOT btrfs, good to know though.
Cheers.
See also:
https://wiki.archlinux.org/title/GRUB/Tips_and_tricks#Changing_the_default_menu_entry
This subject has been discussed before:
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
Thank you sir for your kind reply, Iam going with the solution that you provided, Iam not that good in linux.
As mentioned I had marked your reply as the solution for this post.
And I want to know whether this is the permanent solution or this will be solved in the future?
Thank you, sir
  1. Please don’t call me “sir”: I’m an a-sexual :alien: that reproduces using mitosis. :grin:
  2. Please read this:
Especially the Linux has multiple kernels section, but if you don’t know about any of the other sections, you might find these informative as well.
:bowing_man:
