I keep trying to add a swap partition. I have it set to 31.25GB but when I add a swap according to this wiki tutorial it adds the entire HDD which is a 500GB HDD. How do I select the specific partition?
Please, post your /etc/fstab and output of terminal commands sudo blkid and sudo parted -l.
/etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=E832-7B45 /boot/efi vfat umask=0077 0 2
UUID=40809886-d17c-433b-876f-89a03d053b64 / ext4 defaults,noatime 0 1
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
sudo blkid
/dev/sda1: LABEL_FATBOOT="NO_LABEL" LABEL="NO_LABEL" UUID="E832-7B45" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="62eacffc-cf21-1e47-adf8-75eeed0c029d"
/dev/sda2: UUID="40809886-d17c-433b-876f-89a03d053b64" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="2731d539-9738-b249-8dfc-dd421f2e9500"
/dev/sdb: UUID="925461ec-eacb-45a1-af4c-25dbc5d36137" TYPE="swap"
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop0: TYPE="squashfs"
sudo parted -l
Model: ATA Samsung SSD 850 (scsi)
Disk /dev/sda: 250GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 2097kB 317MB 315MB fat32 boot, esp
2 317MB 250GB 250GB ext4
Model: ATA ST3500312CS (scsi)
Disk /dev/sdb: 500GB
Partition Table: loop
Disk Flags:
Number Start End Size File system Flags
1 0.00B 500GB 500GB linux-swap(v1)
Here’s your problem.
/dev/sdb
is a drive. You should have a number afterwards to note a partition (like /dev/sda1
Did you actually create a partition beforehand in order to set it as swap?
A swap partition can be created in any disk management / partition management tool and should be set as type
linuxswap
Okay it looks like I have no idea what I’m doing here. Thank you for your help I think I need to do some research. I made the entire HDD a linux swap and when I try to resize it it goes back to using the entire HDD instead of staying at 31.25GB.
Is it a brand new drive? You may need to create partition table first, so it records the position of your partitions.
No, it’s old. I’m not sure how to use GParted. I don’t see how to make multiple partitions.
Good reading.
https://gparted.org/display-doc.php?name=help-manual
I figured it out. I wasn’t applying operations in GParted. I formatted the drive then performed the proper procedure. Thank you for the help. I chose your second response as a solution because that’s what I was having trouble with.
