Pcwolf
#1
I occasionally try to install AUR projects and fail with error messages. Such as:
“==> Validating source files with sha256sums…
octoprint-1.7.3.tar.gz … FAILED”
and …
“curl: (22) The requested URL returned error: 404
==> ERROR: Failure while downloading http://www.ishare3d.com/3dapp/public/FlashPrint-5/FlashPrint/flashprint5_5.2.1_amd64.deb
Aborting…
Failed to build flashprint”
QUESTION: How to reach out to maintainers for specific files that show such errors?
First of all, see the Arch Wiki: Foo in the AUR does not compile when I run makepkg; what should I do?
The issue with octoprint
has already been reported, see the comments.
flashprint
is marked out of date. It appears the previous version is no longer available from the upstream server.
Pcwolf
#3
Thanks so much for the reference! I will do my research. Thank you
system
Closed
#4
