soumi
#1
Goo day. I want to run a py script on boot. This is my code
import subprocess
# subprocess.run(['ls'])
subprocess.run(["redshift"])
protonvpn
/run/media/soumi/Luna/CF-0001/Programming/Python/terminal.py
I know it’s simple I just want to test and experiment with the terminal. What should I do so that everytime I boot, this script is executed? Thanks
Hello @soumi
First this is a temporary mount:
which will only mounted there if a user triggers the mount process in the file manager. Bad place for a script which have to run on boot.
Better would be:
$HOME/.local/bin
On KDE there is a autostart setting: System Settings/Autostart - KDE UserBase Wiki
system
closed
#3
