ibus-daemon was supposed to be run at startup but it doesn’t. What should I do?
Shot in the dark here but you could try:
sudo systemctl enable ibus-daemon
to tell systemd to start it at boot up. If it’s a systemd service that should do it.
run
$ ibus-setup
. The daemon will be initialized and provide the following message:IBus has been started! If you cannot use IBus, please add below lines in ~/.bashrc, and relogin your desktop. export GTK_IM_MODULE=ibus export XMODIFIERS=@im=ibus export QT_IM_MODULE=ibus export GTK_IM_MODULE=ibus export XMODIFIERS=@im=ibus export QT_IM_MODULE=ibus
