I install ghidra successfully via pamac. The install history could be seen in pamac history. But I can not find the entry in launcher(Meta). Any advice is welcome.
[2022-07-25T23:48:06+0800] [ALPM] installed ghidra (10.1.4-1)
I took a look at the github page and to start it the command appears to be ghidra
. The package from pamac stores its files in /opt/ghidra. There doesnt appear to be a .desktop file to add it to menu’s. There appears to be an operation cheat sheet that may interest you.
Thanks for your reply. That helps a lot. I find a pkg named ghidra-desktop.
