Kernel 7.2 produces unusable blurry output on DELL U3014 with AMD Radeon RX 6650M, 7.3-rc6 also has this problem, 7.1 was fine. How to revert back to 7.1? i dont care if EOL or not. currently on testing branch.
EDIT: removed “second monitor looks fine.” after switching to 6.18 and realizing that the second monitor is also blurred but not to that extend like the primary.
Your post has been moved to a dedicated Support topic.
Kernel 7.1 has reached EOL and is no longer installable from Manjaro repositories. Consider kernel 6.18 (LTS) instead.
You might also consider updating the firmware for your machine. Beyond that, I’m afraid I have nothing to suggest.
Providing your System Information formatted according to forum guidelines may be helpful. See below. ![]()
inxi -zv8 |
(short-form) |
inxi --filter --verbosity=8 |
(long-form) |
- man inxi (The
inximanual)
Command output should be presented as pre-formatted text in accordance with forum guidelines. ![]()
- Add
--color=0to the long-form command, or… - Change the short-form command to
inxi -zv8c0
Your privacy is respected
Note: Grave accent (or, backtick) characters are used. ![]()
- please follow this simple example:
code here.
- place text beween two rows of three (```) backtick characters to form a scrollable text box, or …
- use the </> button in the Compose window to achieve the same result.
What is a Quark?
The only solution in that case is a backup done before updating : Timeshift is your friend !
You don’t just revert to an unsupported kernel. It is/will be removed.
If you cannot solve the problem in some other way - here is an appropriate reading material -
The only way to use exactly 7.1 will be to find a distro that supports it. Untill it gets updated too, in a couple of months of course. So this is a nonsolution.
Better concentrate on fixing the real problem.
This will tell us if your system is likely to be better supported with a newer Kernel, e.g. linux73; it’s worth giving that a try anyway, if you haven’t already done so. ![]()
Edited to add:
I assume you’ve tried resetting the monitors’ inbuilt calibration …? Not doing this can well result in a “blurred” display when there’s a change in how the driver sends the signal vs. how the monitor currently interprets it.
I regularly had to do this “display calibration” when e.g. changing resolution, particularly on older displays but sometimes new(ish) ones as well.
Yes, that would have been better, guess i got a bit lazy ![]()
❯ inxi --filter --verbosity=8
Kernel: 6.18.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
root=UUID=31fb976d-350b-4769-b598-9777f4544d74 rw rootflags=subvol=@
quiet splash udev.log_priority=3 amdgpu.dcdebugmask=0x10
Desktop: KDE Plasma v: 6.7.5 tk: Qt v: N/A info: frameworks v: 6.30.0
Type: Desktop System: Micro (HK) Tech product: HX100G v: N/A
serial: <superuser required>
Mobo: N/A model: N/A serial: <superuser required>
uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
v: 0.18 date: 09/25/2023
System RAM: total: 64 GiB available: 62.55 GiB used: 9.03 GiB (14.4%)
Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 32 GiB speed: 4800 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: N/A
part-no: F5-4800S3838A32G serial: <filter>
Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 7840HS w/ Radeon 780M Graphics bits: 64
type: MT MCP arch: Zen 4 gen: 4 level: v4 note: check built: 2022+
process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x74 (116) stepping: 1
microcode: 0xA704108
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1101 min/max: 419/5138 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1101 2: 1101 3: 1101
4: 1101 5: 1101 6: 1101 7: 1101 8: 1101 9: 1101 10: 1101 11: 1101 12: 1101
13: 1101 14: 1101 15: 1101 16: 1101 bogomips: 121376
apic arat avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero
cmov cmp_legacy constant_tsc cpb cppc cpuid cpuid_fault cqm cqm_llc
cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
fsgsbase fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse
pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
v_spec_ctrl vaes vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt
x2apic x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 23 [Radeon RX 6650 XT /
6700S 6800S] driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: HDMI-A-1,HDMI-A-2 empty: DP-1,DP-2,Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:73ef class-ID: 0300
Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu d-rect: 4480x1600 display-ID: 0
Monitor-1: HDMI-A-1 pos: primary,left model: Dell U3014 serial: <filter>
built: 2013 res: mode: 2560x1600 hz: 60 scale: 100% (1) dpi: 101 gamma: 1.2
chroma: red: x: 0.682 y: 0.310 green: x: 0.208 y: 0.702 blue: x: 0.145
y: 0.051 white: x: 0.314 y: 0.329 size: 641x401mm (25.24x15.79")
diag: 756mm (29.8") ratio: 16:10 modes: 2560x1600, 1920x1200, 1920x1080,
1600x1200, 1680x1050, 1280x1024, 1280x800, 1152x864, 1280x720, 1024x768,
800x600, 720x576, 720x480, 640x480, 720x400
Monitor-2: HDMI-A-2 pos: right model: BenQ GL2780 serial: <filter>
built: 2021 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2
chroma: red: x: 0.639 y: 0.337 green: x: 0.314 y: 0.627 blue: x: 0.157
y: 0.055 white: x: 0.314 y: 0.329 size: 598x336mm (23.54x13.23")
diag: 686mm (27") ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900,
1280x1024, 1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600,
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 vendor: amd mesa v: 26.2.4-arch1.1 glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 6650M (radeonsi navi23 ACO DRM
3.64 6.18.55-1-MANJARO) device-ID: 1002:73ef memory: 7.81 GiB unified: no
display-ID: :1.0
API: Vulkan v: 1.4.363 layers: 6 device: 0 type: discrete-gpu name: AMD
Radeon RX 6650M (RADV NAVI23) driver: mesa radv v: 26.2.4-arch1.1
device-ID: 1002:73ef surfaces: N/A
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Realtek
driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: c8:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Realtek
bus-ID: c8:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: ASUSTek Xonar U7 MKII driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.1:9
chip-ID: 0b05:183c class-ID: 0300
Device-5: Razer USA Kraken Tournament Edition
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-2.1.3.1:20 chip-ID: 1532:0520 class-ID: 0300
serial: <filter>
Device-6: C-Media Audio Adapter (Unitek Y-247A)
driver: cmedia_hs100b,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-3:6 chip-ID: 0d8c:0014 class-ID: 0300
API: ALSA v: k6.18.55-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.9 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I226-V driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0 chip-ID: 8086:125c
class-ID: 0200
Device-2: MEDIATEK MT7921 802.11ax PCIe Wireless Network Adapter [Filogic
330] driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 06:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF: wlp6s0 state: down mac: <filter>
Info: services: NetworkManager, sshd, systemd-timesyncd
Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:8 chip-ID: 0e8d:7961
Local Storage: total: 4.64 TiB used: 3.65 TiB (78.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 52.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Lexar model: SSD NM790 4TB
size: 3.73 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 12237 temp: 59.9 C scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
used: 312.05 GiB (33.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 31fb976d-350b-4769-b598-9777f4544d74
used: 720 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: F38C-FF63
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
ID-4: /media/gweber/Data1 raw-size: 1.91 TiB size: 1.88 TiB (98.38%)
used: 1.75 TiB (93.4%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:4
label: Data1 uuid: 62964083-8639-4112-934e-d87f4ad4c63a
ID-5: /media/gweber/Data2 raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 1.59 TiB (89.1%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:5
label: Data2 uuid: 0ad2b398-e3a0-4aa4-8c0b-227aa213bff4
ID-6: /media/gweber/av raw-size: N/A size: 32.2 TiB
used: 31.12 TiB (96.7%) fs: cifs dev: /dev/av
ID-7: /media/gweber/windows raw-size: N/A size: 32.2 TiB
used: 31.12 TiB (96.7%) fs: cifs dev: /dev/windows
ID-8: /media/gweber/zzz raw-size: N/A size: 32.2 TiB
used: 31.12 TiB (96.7%) fs: cifs dev: /dev/zzz
ID-9: /var/cache raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
ID-10: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
Hub-2: 1-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
Device-1: 1-1.1:9 info: ASUSTek Xonar U7 MKII type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 5 rev: 2.0
Device-2: 1-1.2:12 info: CHERRY KC 6000 Slim Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 046a:0113 class-ID: 0300
Device-3: 1-1.4:15 info: ROCCAT Kone Aimo 16K type: mouse,keyboard
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1e7d:2e2c class-ID: 0300
Hub-3: 1-2:3 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
Hub-4: 1-2.1:7 info: Texas Instruments Hub ports: 3 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0451:8043
Hub-5: 1-2.1.3:11 info: Texas Instruments Hub ports: 3 rev: 2.1
Device-1: 1-2.1.3.1:20 info: Razer USA Kraken Tournament Edition
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 6
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 500mA
chip-ID: 1532:0520 class-ID: 0300 serial: <filter>
Device-2: 1-2.1.3.2:18 info: GAOMON Tablet_M1230 type: mouse,HID
lanes: 1 mode: 1.1 power: 480mA chip-ID: 256c:006f class-ID: 0300
Device-3: 1-2.1.3.3:19 info: Realtek Card Reader type: mass storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:0307 class-ID: 0806
serial: <filter>
Hub-6: 1-2.2:10 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2822
Device-1: 1-3:6 info: C-Media Audio Adapter (Unitek Y-247A)
type: audio,HID driver: cmedia_hs100b,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Device-2: 1-5:8 info: MediaTek Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 0e8d:7961 class-ID: e001 serial: <filter>
Hub-7: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-8: 2-1:2 info: Genesys Logic USB3.2 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0625
Hub-9: 2-2:3 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
Hub-10: 2-2.2:4 info: VIA Labs USB3.1 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0822
Hub-11: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-12: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-13: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-14: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-15: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-16: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 49.8 C mobo: N/A gpu: amdgpu temp: 56.0 C
mem: 58.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Packages: 2220 pm: dpkg pkgs: 0 pm: pacman pkgs: 2188 libs: 550 tools: pamac
pm: flatpak pkgs: 32
1: https://ftp.belnet.be/mirrors/manjaro/repos/testing/$repo/$arch
2: https://mirror.bakertelekom.fr/manjaro/testing/$repo/$arch
3: https://mirror.dkm.cz/manjaro/testing/$repo/$arch
4: https://ftp.tu-chemnitz.de/pub/linux/manjaro/testing/$repo/$arch
5: https://opencolo.mm.fcix.net/manjaro/testing/$repo/$arch
Processes:
CPU top: 5 of 531
1: cpu: 7.1% command: chromium pid: 779133 mem: 574.1 MiB (0.8%)
2: cpu: 6.1% command: kwin_wayland pid: 1256 mem: 300.7 MiB (0.4%)
3: cpu: 4.2% command: chromium pid: 4651 mem: 863.3 MiB (1.3%)
4: cpu: 3.2% command: chromium pid: 4699 mem: 217.1 MiB (0.3%)
5: cpu: 3.0% command: remmina pid: 1760 mem: 541.7 MiB (0.8%)
Memory top: 5 of 531
1: mem: 863.3 MiB (1.3%) command: chromium pid: 4651 cpu: 4.2%
2: mem: 574.1 MiB (0.8%) command: chromium pid: 779133 cpu: 7.1%
3: mem: 573.7 MiB (0.8%) command: plasmashell pid: 1451 cpu: 1.9%
4: mem: 554.1 MiB (0.8%) command: kdevelop pid: 504203 cpu: 0.0%
5: mem: 541.7 MiB (0.8%) command: remmina pid: 1760 cpu: 3.0%
Processes: 531 Power: uptime: 15h 13m states: freeze,mem,disk
suspend: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 24.97 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
tool: systemctl
Compilers: clang: 23.1.1 gcc: 16.2.1 Shell: Zsh v: 5.9.2
running-in: konsole inxi: 3.3.41
Regarding calibration: will try that tomorrow
One has to bear in mind that a “rollback” of any sort on a Rolling Release distro is only ever going to be a temporary measure. ![]()
By the way, I’ve merged your consecutive posts and added @mentions (and spacers); it’s always encouraged to edit your previous post if there are no intervening replies. Just keeps things tidy. ![]()
You can only revert to an unsupported kernel by building it locally.
Using the topic [How To] Compile a custom Manjaro kernel
And added benefit is the kernel is being maintained by the package manager using a custom package name, thus not being replaced by an update to the repository kernel
You can amend the script to look like below
#!/usr/bin/env bash
####---- version 14 ----####
# [date=2026-10-02 time=09:30:00 timezone="Europe/Copenhagen"]
# define manjaro kernel name to work with
if [[ -z $1 ]]; then
echo "FAILURE: Kernel must be supplied e.g. 'linux72'."
exit 1
else
manjaro_kernel="$1"
fi
# define builddir - default to user's home
# if you change - remember to create the path beforehand
builddir=$HOME
# define custom kernel identifier
custom="-custom"
# define custom build host
host="$(hostnamectl hostname)"
# define custom build user
user=$USER
# define the kernel configuration path
kernel_config=${builddir}/${manjaro_kernel}/core/${manjaro_kernel}/config
# define the pkgbuild path
pkgrecipe=${builddir}/${manjaro_kernel}/core/${manjaro_kernel}/PKGBUILD
# cd into builddir
cd ${builddir}
# remove ${manjaro_kernel} dir if it exist
[[ -d ${builddir}/${manjaro_kernel} ]] && rm -rf ${builddir}/${manjaro_kernel}
# clone Manjaro package build recipe
git clone -n --depth=1 --filter=tree:0 https://code.manjaro.org/packages/PKGBUILDs.git ${builddir}/${manjaro_kernel}
cd ${builddir}/${manjaro_kernel}
git sparse-checkout set --no-cone core/${manjaro_kernel}
git checkout
# change working folder
cd ${builddir}/${manjaro_kernel}/core/${manjaro_kernel}
# modify build recipe
# add '-${custom}' to kernel name
sed -i 's|^_kernelname=.*|_kernelname=\"'${custom}'\"|g' ${pkgrecipe}
# add '-${custom}' to package base name
sed -i 's|^pkgbase=.*|pkgbase="linux\${_basever}'${custom}'\"|g' ${pkgrecipe}
# add '-${custom}' to the base kernel name
sed -i 's|\"\${_basekernel}-\${CARCH}\"|\"\${_basekernel}-'${custom}'\${CARCH}\"|g' ${pkgrecipe}
# modify kernel config
# set KBUILD_BUILD_HOST to ${host}
sed -i 's|^export KBUILD_BUILD_HOST=.*|export KBUILD_BUILD_HOST=\"'${host}'\"|g' ${pkgrecipe}
# set KBUILD_BUILD_USER to ${user}
sed -i 's|^export KBUILD_BUILD_USER=.*|export KBUILD_BUILD_USER=\"'${user}'\"|g' ${pkgrecipe}
# set kernel config CONFIG_LOCALVERSION to '${custom}'
sed -i 's|^CONFIG_LOCALVERSION=.*|CONFIG_LOCALVERSION=\"'${custom}'\"|g' ${kernel_config}
# set kernel config CONFIG_DEFAULT_HOSTNAME to ${host}
sed -i 's|^CONFIG_DEFAULT_HOSTNAME=.*|CONFIG_DEFAULT_HOSTNAME=\"'${host}'\"|g' ${kernel_config}
# update pkgsums
updpkgsums
# run makepkg with install and cleanup
PKGDEST=${builddir}/${manjaro_kernel} makepkg -sicC
