How to return the previous behaviour of desktop icons selection
Can anyone help me? What should I add into “/home/user/.config/gtk-3.0/gtk.css” to return the previous behavior of desktop icons selection. With xfce 4.20 there appeared a white background on mouse hover.
I would like to make it transparent again.
P.S. Why manjaro team has stopped to maintain the consistency of the manjaro UI theme? I remember, that icon (hide windows) should also be in #2eb398 color )
One of these codes, should do the trick:
XfdesktopIconView.view  {
  background-color: transparent;
  XfdesktopIconView.view:active {
    background: transparent;
  XfdesktopIconView.view .label {
EDIT:
Then execute
xfdesktop --quit ; xfdesktop &
EDIT2:
Also try:
XfdesktopIconView.view .label:hover { backgorund-color: transparent; }
Since you said
Oh. OK, we are waiting for the Matcha theme update (Xfce 4.20 issues · Issue #238 · vinceliuice/Matcha-gtk-theme · GitHub). Sorry, manjaro team :slight_smile:
@D.Dave Thank you, you showed me the right css class. Actually the following addition to gtk.css fixes the icon behavior:
XfdesktopIconView:selected:hover {
  background-color: #29a189;
XfdesktopIconView:hover {
  color: white;
I’m glad you solved, so you can mark my reply as solution.
