I can’t boot my pc since i updated. And i think this stems from new kernel. Current version is linux515, i want to return linux54. How does it?
You can have multiple kernels installed at the same time. If you already have, you can choose them from the GRUB menu. If not, you can install another version in a chroot from a live ISO.
See:
Boot up from the installer CD/DVD/USB in live mode. Then open up a terminal window and issue the following commands…
sudo su -
manjaro-chroot -a
mhwd-kernel -i linux54
sync
exit
systemctl reboot
At the GRUB menu, choose "Advanced options for Manjaro Linux". Select the 5.4 kernel. After your system has booted up, you can remove the 5.15 kernel with…
sudo mhwd-kernel -r linux515
how to open grub menu
im newbie this platform
Tap Esc or hold Shift while booting.
In addition to what @Yochanan said, if you want to make the GRUB menu permanently visible at every boot, open up the file /etc/default/grub and look for this line ─ it’s near the top of the file…
GRUB_TIMEOUT_STYLE=hidden
Change that into…
GRUB_TIMEOUT_STYLE=menu
… and save the file. Then run the following command in a terminal window…
sudo update-grub
i boot from usb and wrote your codes and its not working unfortunately
What do you mean by “It’s not working”?
Always remember that the quality of the help you’ll get depends on the quality of the information you provide. A line like “It’s not working” doesn’t tell us anything.
thank you so much, i boot with the version i want. but the computer still can’t open
Then your initial hypothesis
might be wrong if you boot with the different kernel and if I uderstand your words
correctly then you boot to black screen again.
AMD Athlon II X4 620 is your Processor? It is quite old. You should better try a Linux distribution which is specially developed for old hardware. My recommendation is antiX.
