I have installed oh my zsh and have lost the default manajaro configuration, which opens a terminal every time you press crtl+t, which has somewhat different options than the conventional xfce4 terminal
LANG=C xfce4-settings-manager
or use the mouse to access the settings
go to âKeyboardâ - and then the âApplication Shortcutsâ tab
and change it to your liking.
this is not a function of the shell - it has got nothing to do with you installing âoh my zshâ
I just made the situation worse and I donât even remember what I did, now I have this error.
âthe secondary process could not be executed
failure to execute child process < failed to execve:file or directory does not exist.â
theme Dracula
change your theme or reset to the default - or to something else at least
also:
you can always copy from /etc/skel the default files to the corresponding place in your $HOME directory
which is
./.config
do one thing at a time, check for effect
keep notes ![]()
thank you very much, I also found how to set the default terminal version of manjaro xD, I think I moved it by accident.
xfce4-terminal --drop-down
To get rid of the error open the preferences in Xfce4 Terminal and uncheck the option called âRun a custom command instead of my shellâ.
