Hello,
I have recently bought a larger ssd drive and migrated to it. I simply cloned the original ssd drive with dd and I could boot to the new drive perfectly. My fdisk outpout as follows.
sda1 is boot fat32
sda2 is efi fat32
sda3 basically lvm controlled device. I want sda3 to expand to the rest of the device.
sudo fdisk -l
GPT PMBR size mismatch (234441647 != 937703087) will be corrected by write.
The backup GPT table is not on the end of the device.
Disk /dev/sda: 447,13 GiB, 480103981056 bytes, 937703088 sectors
Disk model: KIOXIA-EXCERIA S
Disklabel type: gpt
Disk identifier: 3DAA5080-18BC-4928-AC54-ADEEF8C85D54
Device Start End Sectors Size Type
/dev/sda1 2048 1050623 1048576 512M Microsoft basic data
/dev/sda2 1050624 1574911 524288 256M EFI System
/dev/sda3 1574912 234436511 232861600 111G Linux filesystem
Disk /dev/mapper/vg1-lvhome: 60 GiB, 64424509440 bytes, 125829120 sectors
Disk /dev/mapper/vg1-lvswap: 8 GiB, 8589934592 bytes, 16777216 sectors
Disk /dev/mapper/vg1-lvroot: 30 GiB, 32212254720 bytes, 62914560 sectors
How can I extend the lvm drive which sda3 to encompass the rest of the disk device?
Any help much appreciated.
