I am a long time GNOME user, and due to some issues with my laptop, I removed gnome and installed xfce. So far I have had no major issues. Its very neat and easy to configure. However, I tried to make some changes to my default panel, and now it has different look and items displayed.
I want to know how to reset my panel to look as it is by default in manjaro xfce. Is there any reset to manjaro-default feature or do I have to manually make changes to get the look back?
I found a very crude way of restoring it to manjaro defaults. I made a new user and copied the .config folder to my user .config and replaced the files. I then restarted my machine, and now I have the default manjaro xfce look!
I tried that, but nothing changed, even after restarting my system. So I went with my method. It would be nice if distros had some “reset to default look” tools for xfce.
