How to replace Gnome keyring with KeepassXC as secret service?
I can’t set KeepassXC as my secret service because gnome-keyring-daemon is running:
I can’t find a service with keyring in its name:
$ systemctl list-units --type=service | grep keyring                                                              0|1 ✘
$ sudo systemctl list-units --type=service | grep keyring                                                         0|1 ✘
Not even a systemd unit file containing the process name gnome-keyring-daemon:
$ sudo grep -r "gnome-keyring-daemon" /etc/systemd/system /lib/systemd/system /run/systemd/system /etc/systemd/user        1 ✘
Looking through all the autostart locations I found a few mentions of that process:
find ~/.config/autostart /etc/xdg/autostart /usr/share/autostart -type f -name '*.desktop' -exec grep -H 'gnome-keyring-daemon' {} \;
/etc/xdg/autostart/gnome-keyring-pkcs11.desktop:Exec=/usr/bin/gnome-keyring-daemon --start --components=pkcs11
/etc/xdg/autostart/gnome-keyring-secrets.desktop:Exec=/usr/bin/gnome-keyring-daemon --start --components=secrets
/etc/xdg/autostart/gnome-keyring-ssh.desktop:Exec=/usr/bin/gnome-keyring-daemon --start --components=ssh
But can I safely remove those? What would be the right way to replace the Gnome keyring with KeepassXC?
Hi @0x0,
I believe this might help:
…and/or:
…and/or:
https://c3pb.de/blog/keepassxc-secrets-service.html
…and/or:
…ad infinitum.
The instructions to disable Gnome Keyring are not working. As soon as I reboot, it’s using Gnome Keyring again.
Try masking the Gnome keyring service?
Edit:
Or you could try removing it:
pamac remove gnome-keyring
Restoring it if wanted:
pamac install gnome-keyring
As I said, I could not find such a service. I don’t think Gnome keyring is a systemd service.
There are too many packages depending on gnome-keyring to remove it like deja-dup, geary, seahorse, xdg-desktop-portal-gnome.
Seeing as I use Plasma, thank goodness, I wouldn’t know then…
Sorry.
:sob:
I am on XFCE and i have
and
/usr/lib/systemd/user/gnome-keyring-daemon.service
Non of which is active, and yet is see the process gnome-keyring-daemon as running? So i guess something else is starting it.
After checking the process hierarchy and seeing that gnome-keyring-daemon is in fact started by systemd, I spent more time searching through systemd and after a while I wound something, so I must correct myself. While there is no regular systemd service that starts gnome-keyring-daemon, there is a user service that does it. I managed to disable it using the --user flag:
systemctl --user mask gnome-keyring-daemon
But after rebooting there still is a gnome-keyring-daemon process running. Checking the process hierarchy again, I can see that it is literally being started by init as in the root parent process of everything. There are 4 instances all started like this:
/usr/bin/gnome-keyring-daemon --daemonize --login
/etc/xdg/autostart/gnome-keyring-*.desktop can be ruled out because those files would start it with different flags:
You can use systemctl status to check which service, slice and/or scope the processes are associated with. Do not use grep, you can search in the pager like in less.
Okay, but what is this telling me?
    State: running
    Units: 395 loaded (incl. loaded aliases)
     Jobs: 0 queued
   Failed: 0 units
    Since: Fri 2023-08-25 16:39:56 CEST; 1h 3min ago
  systemd: 253.8-1-manjaro
   CGroup: /
           ├─init.scope
           │ └─1 /sbin/init splash
           ├─system.slice
           └─user.slice
             └─user-1000.slice
               ├─session-1.scope
               │ ├─ 755 "gdm-session-worker [pam/gdm-autologin]"
               │ ├─ 774 /usr/bin/gnome-keyring-daemon --daemonize --login
               │ ├─ 779 /usr/lib/gdm-wayland-session /usr/bin/gnome-session
               │ ├─ 784 /usr/lib/gnome-session-binary
               │ └─1858 /usr/bin/ssh-agent -D -a /run/user/1000/keyring/.ssh
I think it’s being started by GDM via PAM. Try cat /etc/pam.d/gdm (I assume that’s the correct file, I don’t use GNOME).
See GNOME/Keyring - ArchWiki
That file does not exist on my system. There are however some files starting with gdm- in that directory:
/etc/pam.d/gdm-autologin:
#%PAM-1.0
auth       required                    pam_shells.so
auth       requisite                   pam_nologin.so
auth       optional                    pam_permit.so
auth       required                    pam_env.so
auth       [success=ok default=1]      pam_gdm.so
auth       optional                    pam_gnome_keyring.so
account    include                     system-local-login
password   required                    pam_deny.so
session    include                     system-local-login
session    optional                    pam_gnome_keyring.so auto_start
/etc/pam.d/gdm-fingerprint:
#%PAM-1.0
auth       requisite                   pam_faillock.so      preauth
auth       required                    pam_fprintd.so
/etc/pam.d/gdm-launch-environment:
#%PAM-1.0
auth       required                    pam_succeed_if.so    audit quiet_success user in gdm:gnome-initial-setup
account    required                    pam_succeed_if.so    audit quiet_success user in gdm:gnome-initial-setup
account    optional                    pam_permit.so
session    optional                    pam_loginuid.so
session    optional                    pam_keyinit.so       force revoke
session    required                    pam_succeed_if.so    audit quiet_success user in gdm:gnome-initial-setup
session    optional                    pam_permit.so
-session   optional                    pam_systemd.so
session    required                    pam_env.so
/etc/pam.d/gdm-password:
#%PAM-1.0
auth       include                     system-local-login
password   include                     system-local-login
password   optional                    pam_gnome_keyring.so use_authtok
/etc/pam.d/gdm-smartcard:
#%PAM-1.0
auth       required                    pam_pkcs11.so        wait_for_card card_only
Yes it looks like GDM. Remove or comment out all lines that includes pam_gnome_keyring.so . You might want to check all files in that folder for pam_gnome_keyring.so . Just a warning, PAM is kind of important. Make sure you know how to login if GDM stopped working.
Could I still log in from tty in case GDM stops working?
If you only edit PAM files used by GDM, yes. Also it is just a precaution.
Okay, if I can’t even get access from tty in case of GDM going bad, I don’t know how I could log in.
Can I maybe create a new snapshot in Timeshift before making the changes and then revert to that snapshot from outside the OS in case GDM goes bad?
Of course, also I just wanted to warn you since PAM is important, but all PAM lines with pam_gnome_keyring.so are optional, so if you just commented these lines out, there is no problem.
I was not able to boot anymore after making these changes. I had to manually restore the files from a live USB stick. I was not able to restore my timeshift snapshot because Manjaro apparently just instantly boots without a grub menu to restore a timeshift snapshot.
GDM and also PAM has nothing to do with the boot process. A boot problem has nothing to do the changing files in /etc/pam.d/. So what do you mean by not “able to boot anymore”.
You need to hint ESC with the normal Grub configuration to see the menu.
I don’t know when exactly it happened because Manjaro seems to use the quiet kernel parameter. But I didn’t get beyond the boot splash logo. However you may define “booting”, it happened before the login screen even showed up. It just froze with the vendor boot logo.
I tried that but it threw me into rescue mode so that I wasn’t even able to type my LUKS password.
