I was working on the python 3.9 or 3.10. However, I accidentaly remove python and PACMAN from my system. I was shocked to know how that could happen. It was not my intention to remove PACMAN. So my urgent request is How can I get PACMAN back so that I can install/upgrate my system in the future?
With pacman-static: pacman - ArchWiki
how did you managed to remove it, its greyed out in the gui…
try this:
wget https://pkgbuild.com/~morganamilo/pacman-static/x86_64/bin/pacman-static
chmod +x pacman-static
./pacman-static -Syyu pacman
Don’t call it an accident - it was a deliberate action from your side - you were using sudo - even logged in as root.
There is no protection from ignorance or outright stupidity.
