After the recent update, when I turn on my laptop it starts here and I have to press super to start working, which is a bit annoying. I tried going through the settings, tweaks and gnome extensions to change it but didn’t find anything useful.
super
settings
tweaks
gnome extensions
is there a way to disable the dock or something else so that my laptop starts at the desktop after restart?
Install the gnome-shell extension No overview at start-up.
Or: Extension Dash to Panel - third tab from the left: “Disable show overview on startup”. . Extension “Hot Edge” may help you further
Hope official dash 2 dock includes this option.
Thnx for this.
DtD replaces original Gnome40 dock…
I don’t see this option
thanks a lot. it solved my issue.
@zoro11 I think this is the option.
thanks
