I use mangohud to monitor my internals and I have watched them for several days since I got this new machine, in all sorts of different scenarios.
Now I know that on this machine, the RTX3060 is rated for a maximum of 130W, but it seems to be capped at 80W. No matter the power mode I use, it always stays around 79-80W.
Any idea how I can get it to run at it’s full potential?
Kernel: 5.19.8-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/vmlinuz-linux
root=UUID=881825ad-972b-491a-b2ce-6d2722e5e85e rw rootfstype=ext4
loglevel=3 ibt=off
Desktop: GNOME v: 42.4 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Distro: Arch Linux
Type: Laptop System: LENOVO product: 82JM v: Legion 5 17ITH6H
serial: <superuser required> Chassis: type: 10 v: Legion 5 17ITH6H
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: H1CN49WW date: 08/16/2022
ID-1: BAT0 charge: 83.5 Wh (100.0%) condition: 83.5/80.0 Wh (104.4%)
volts: 17.5 min: 15.4 model: Celxpert L20C4PC2 type: Li-poly
serial: <filter> status: full
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 built: 2020 process: Intel 10nm
family: 6 model-id: 0x8D (141) stepping: 1 microcode: 0x40
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 2345 high: 3696 min/max: 800/4600 scaling:
driver: intel_pstate governor: performance cores: 1: 2300 2: 2300 3: 2300
4: 2300 5: 1639 6: 2300 7: 2300 8: 2300 9: 2300 10: 2300 11: 2300
12: 2300 13: 2300 14: 2300 15: 3696 16: 2300 bogomips: 73744
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 515.65.01 non-free: 515.xx+ status: current (as of
2022-08) arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22
pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 01:00.0 chip-ID: 10de:2560 class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-6:2 chip-ID: 174f:2459 class-ID: fe01 serial: <filter>
Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: X: loaded: nvidia unloaded: modesetting
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: DP-4 res: 1920x1080 hz: 144 dpi: 128
size: 382x215mm (15.04x8.46") diag: 438mm (17.26") modes: N/A
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Tiger Lake-H HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Sound Server-1: ALSA v: k5.19.8-arch1-1 running: yes
Sound Server-4: PipeWire v: 0.3.58 running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
IF: wlan0 state: down mac: <filter>
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 58:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp88s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 3-14:4 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.16 TiB used: 585.47 GiB (49.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus
250GB size: 232.89 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7
temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: SK Hynix model: HFS001TDE9X084N
size: 953.87 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41010C22
temp: 37.9 C scheme: GPT
ID-1: / raw-size: 232.38 GiB size: 227.68 GiB (97.97%) used: 160.42 GiB
(70.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot raw-size: 511 MiB size: 510 MiB (99.80%) used: 87.6 MiB
(17.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 4 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/zram0
System Temperatures: cpu: 39.0 C mobo: N/A
Processes: 324 Uptime: 8m wakeups: 11 Memory: 15.48 GiB used: 2.85 GiB
(18.4%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1241
libs: 421 tools: gnome-software,pamac,yay pm: flatpak pkgs: 0 Shell: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.21
