I’ve been reading Python2 aur error in check() on update. I like to know what’s the best way to remove python2 and “the handful packages that depended on it”. If i remove just python2 with pamac gui, will all dependencies also be removed? Or do i need to do it in the terminal? If yes, which command is best and most safe?
Thanks a lot!
