I installed correctly manjaro-Pipewire to install LXQT but PulseAudio preferences is runing on menu and when i give clic to run so pulseaudio preferences not open. I want remove.
sudo systemctl disable --user --now pulseaudio
if this doesn’t work remove --user
sudo pacman -Rns manjaro-pulse
pamac remove paprefs
That Is not solution. Thanks for write.
Thanks. This is solve.
