How to remove close button from system tray?
After some playing with layouts, in Firefox I got two pairs of close, minimize and restore buttons - in system tray and in the corner of window. And for other applications only in system tray. How can I remove them from system tray and place them to standard positions?
You might have enabled Unite gnome extension … disable it.
You are right! Thanks!
