The title says it all. I am new to linux and installed Chaotic AUR (following the instruction on the website) on a fluke. Now I realized I don’t need that. Could somebody please tell me how to remove it in a clean way?
Tq
Tq
Hi @sureshs2004,
AFAIK it’s as easy as deleting the relevant section from /etc/pacman.conf
If I’m wrong, someone please feel free to correct me.
I’m checking as we speak.
I see the keys can be deleted, but to do that we need to know which one to delete. To see which ones are installed, run:
pacman-key --list-keys
That’ll give you a list of currently installed keys.
And the rest is plain guesswork, so might be wrong and carries no guarantees!!!
I’m guessing the chaotic-aur signature will look something like this:
pub rsa4096 2021-04-05 [SC] [expires: 2023-04-05]
3FFA0B5E092ED4095E26F69B8ADB4AEC585061CF
uid [ full ] Nico Jensch (Chaotic-AUR birdrepo builder) <dr460nf1r3@garudalinux.org>
sub rsa4096 2021-04-05 [E] [expires: 2023-04-05]
So I’m guessing they key can be deleted as follows:
pacman-key --delete 3FFA0B5E092ED4095E26F69B8ADB4AEC585061CF
I don’t know for certain, though. This is just guesswork!
Nico Jensch is also a packager of several aur packages, tho. Does it matter regarding his key used there?
Edit: honest question. Do people reuse one or two of their keys to upload their apps to aur?
Thanks! I didn’t install any AUR app, so it was the only key with his name, so …
I’m guessing not, since the AUR is not the Chaotic-AUR…
You missed the part about the packages:
sudo pacman -Rns chaotic-keyring chaotic-mirrorlist
And then since we messed with mirrors a database refresh is required (which means a sync/upgrade is as well)…
sudo pacman-mirrors -f && sudo pacman -Syyu
(I included pacman-mirrors sorting here, even if it is not necessary, because … why not)
Well, that wasn’t too bad for guessing then…
