I installed a new gpg key then found out it was not needed after all. How do I remove the offending key?
I used ‘gpg --recv-keys EB4F9E5A to install it’.
https://archlinux.org/pacman/pacman-key.8.html
pacman-key -d EB4F9E5A
Excellent. Thanks. Did not even think of looking over at arch.
Nope. The Pacman keyring and public keyring are two different things.
Then use
gpg --delete-key EB4F9E5A
See man gpg
Now it’s gone. Using pacman-key -d EB4F9E5A gave no errors so I thought it was gone.
Using gpg --delete-key EB4F9E5A definitely got rid of it.
Thanks @Yochanan
