Putting the title in context:
The machine hardware is active since 2015.
only yesterday started to have some problems with Firefox crashing in several ARCH based distros .
Manjaro by default starts in Init 3 level and I call manually via ssdm the GUI.
After some crashes I had to fsck the Manjaro “/” filesystem; where I started to have several inode errors.
Everytime I get different errors … In different calls … in different distros …
Initially thought about a bad ext4 filesystem ( SATA SSD ) …
But somehow I managed to startup memtest+ and then noticed that problem were in the DDR RAM .
So I had to remove the incorrect DDR RAM stick and the issues disappeared …
During the previous tryouts and experiments noticed several random file deletions in the filesystem structure .
So I Knew I had to first reinstall the Linux kernel package but how about the others ?
Reinstalled also the XFCE package …
Everything seems to work Ok
( as I am writing this in the Manjaro distro) but :
If I call :
pacman -S $(pacman -Qeq) --noconfirm
I get a full list both with reinstall warnings and errors … But it does not execute nothing …
Is there any options in the pamac to do the same thing ? Or even yay ?
From the existing application database would it possible to forcefully reinstall all packages ?
