Hi the community
I deleted a file … too fast
Please, How to recover it ?
Manjaro KDE uptodated.
thanks to earing from you
Hi the community
I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (I just want to avoid even more subjective opinions being posted and confusing you even more)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most :
HI,
Both responses are appreciated.
From Photorec you can not choose the type of file (sample jpg or vts … file)
You can only recover all the files of the disk … that takes time and place.
Some idea to select a type of file or the name of file when we know it ?
Thanks a lot
testdisk takes more time to recover a file as it’s a generic tool, not specialised in anything, contrarily to PhotoRec.dd of that disk to another diskThis won’t help you right now, but for the future, please read this:
Thanks Fabby. Thanks a lot. I had not seen the security aspects !
In fact Arch don’t have any tool as Recuva, an offline recovery application where we can select the files to recover ? too bad
Regards
Actually, PhotoRec and TestDisk are far superior to Recuva and are used by the forensic labs of multiple
police departments…
As you never told us which kind of file you’re trying to recover, we can only offer generic advice, but the best recovery tool of anything out there, is a backup!
