How to rebuild initramfs?
Hello,
i have a question about how to rebuild initramfs. i need to do it since its neccesary for a program to work. that program is for managing FAN and Power control on my razer blade 15. but i dont know how to do it, and i cant find anything that points me in the right direction, or i am blind :wink:
Could anyone help me with this problem?
Kind regards
MagicGnome
sudo mkinitcpio -p linux
Replace linux with linux-lts if u have lts kernel
when i do that i get
/usr/bin/mkinitcpio: line 268: /etc/mkinitcpio.d/linux.preset: No such file or directory
==> ERROR: Failed to load preset: `/etc/mkinitcpio.d/linux.preset’
sudo mkinitcpio -p linux56
/usr/bin/mkinitcpio: line 268: /etc/mkinitcpio.d/linux56.preset: No such file or directory
==> ERROR: Failed to load preset: `/etc/mkinitcpio.d/linux56.preset’
What if you use an existing kernel then?
Just regenerate all available ones with sudo mkinitcpio -P
thanks!
Btw. I hope you’re not running that kernel version anymore, it’s EOL (since that statement failed though I guess you’re not). :wink:
can you please return
sudo mhwd-kernel -li
sudo ls /etc/mkinitcpio.d/*.preset
number and kernels version must match
