How to read files permissions in numeric format?
When we do: ls -l we get something like:
-rw-r--r-- 1 jm jm 0 05-23 11:41 test
I’m aware that in numeric format it’s 644.
Is there a way to read it somehow to get:
644 1 jm jm 0 05-23 11:41 test
Or something similar?
Please read my very elaborate tutorial on the subject… :arrow_down:
:slight_smile:
I’ll definitely do but I’m curious right now :slight_smile:
Is there an answer to my question or just explanation of the subject?
I know that read is 4 write is 2 and execute is 1, and we can add them to get desired permission.
stat filename :wink:
or example (use %a read man):
stat -c '%n %U:%G %a = %A %F' $HOME/*
echo -e "$(stat -c '%n %U:%G \033[32m%a\033[0m = %A %F' $HOME/*)"
Exactly what I needed. Thank you!!! :smiley:
Cool.
Just an alternative… If --printf rather -c is used, the echo -e and command substitution can be eliminated. A ‘\n’ needs to be added though.
gnu doc
