I try to set up dnscrypt along side with systemd-resolver and NetworkManager on manjaro.
So
- I modify
/etc/systemd/resolved.conf
[Resolve]
DNS=127.0.0.1:53
FallbackDNS=
- I symlink
/etc/resolv.confto/run/systemd/resolve/stub-resolv.conf - I modify
/etc/dnscrypt-proxy/dnscrypt-proxy.toml
listen_addresses = ['127.0.0.1:53']
- I start/enable dnscrypt-proxy and systemd-resolved
- the output of resolvectl status is:
Global
Protocols: +LLMNR +mDNS -DNSOverTLS DNSSEC=no/unsupported
resolv.conf mode: stub
Current DNS Server: 127.0.0.1
DNS Servers: 127.0.0.1
Link 2 (enp2s0)
Current Scopes: none
Protocols: -DefaultRoute +LLMNR +mDNS -DNSOverTLS DNSSEC=no/unsupported
Default Route: no
Link 3 (wlp3s0)
Current Scopes: DNS LLMNR/IPv4 LLMNR/IPv6 mDNS/IPv4 mDNS/IPv6
Protocols: +DefaultRoute +LLMNR +mDNS -DNSOverTLS DNSSEC=no/unsupported
Current DNS Server: 192.168.1.1
DNS Servers: 192.168.1.1 fe80::1 fd80::e66f:13ff:feac:5b61
Default Route: yes
how to get domain name not resolved at all if I stop dnscrypt-proxy?
that is not the case presently.
$ cat /etc/systemd/resolved.conf
# This file is part of systemd.
# systemd is free software; you can redistribute it and/or modify it under the
# terms of the GNU Lesser General Public License as published by the Free
# Software Foundation; either version 2.1 of the License, or (at your option)
# any later version.
# Entries in this file show the compile time defaults. Local configuration
# should be created by either modifying this file (or a copy of it placed in
# /etc/ if the original file is shipped in /usr/), or by creating "drop-ins" in
# the /etc/systemd/resolved.conf.d/ directory. The latter is generally
# recommended. Defaults can be restored by simply deleting the main
# configuration file and all drop-ins located in /etc/.
# Use 'systemd-analyze cat-config systemd/resolved.conf' to display the full config.
# See resolved.conf(5) for details.
[Resolve]
# Some examples of DNS servers which may be used for DNS= and FallbackDNS=:
# Cloudflare: 1.1.1.1#cloudflare-dns.com 1.0.0.1#cloudflare-dns.com 2606:4700:4700::1111#cloudflare-dns.com 2606:4700:4700::1001#cloudflare-dns.com
# Google: 8.8.8.8#dns.google 8.8.4.4#dns.google 2001:4860:4860::8888#dns.google 2001:4860:4860::8844#dns.google
# Quad9: 9.9.9.9#dns.quad9.net 149.112.112.112#dns.quad9.net 2620:fe::fe#dns.quad9.net 2620:fe::9#dns.quad9.net
DNS=127.0.0.1:53 # <----------
#FallbackDNS=1.1.1.1#cloudflare-dns.com 9.9.9.9#dns.quad9.net 8.8.8.8#dns.google 2606:4700:4700::1111#cloudflare-dns.com 2620:fe::9#dns.quad9.net 2001:4860:4860::8888#dns.google
FallbackDNS= # <-------------------
#Domains=
#DNSSEC=no
#DNSOverTLS=no
#MulticastDNS=yes
#LLMNR=yes
#Cache=yes
#CacheFromLocalhost=no
#DNSStubListener=no
#DNSStubListenerExtra=
#ReadEtcHosts=yes
#ResolveUnicastSingleLabel=no
#StaleRetentionSec=0
resolv.conf
$ readlink /etc/resolv.conf
** dnscrypt-proxy config **
$ cat /etc/dnscrypt-proxy/dnscrypt-proxy.toml
# dnscrypt-proxy configuration #
## This is an example configuration file.
## You should adjust it to your needs, and save it as "dnscrypt-proxy.toml"
## Online documentation is available here: https://dnscrypt.info/doc
# Global settings #
## List of servers to use
## Servers from the "public-resolvers" source (see down below) can
## be viewed here: https://dnscrypt.info/public-servers
## The proxy will automatically pick working servers from this list.
## Note that the require_* filters do NOT apply when using this setting.
## By default, this list is empty and all registered servers matching the
## require_* filters will be used instead.
## Remove the leading # first to enable this; lines starting with # are ignored.
# server_names = ['scaleway-fr', 'google', 'yandex', 'cloudflare']
## List of local addresses and ports to listen to. Can be IPv4 and/or IPv6.
## Example with both IPv4 and IPv6:
## listen_addresses = ['127.0.0.1:53', '[::1]:53']
## To listen to all IPv4 addresses, use `listen_addresses = ['0.0.0.0:53']`
## To listen to all IPv4+IPv6 addresses, use `listen_addresses = ['[::]:53']`
listen_addresses = ['127.0.0.1:53'] # <------
## Maximum number of simultaneous client connections to accept
max_clients = 250
## Switch to a different system user after listening sockets have been created.
## Note (1): this feature is currently unsupported on Windows.
## Note (2): this feature is not compatible with systemd socket activation.
## Note (3): when using -pidfile, the PID file directory must be writable by the new user
# user_name = 'nobody'
# Server Selection #
## Require servers (from remote sources) to satisfy specific properties
# Use servers reachable over IPv4
ipv4_servers = true
# Use servers reachable over IPv6 -- Do not enable if you don't have IPv6 connectivity
ipv6_servers = false
# Use servers implementing the DNSCrypt protocol
dnscrypt_servers = true
# Use servers implementing the DNS-over-HTTPS protocol
doh_servers = true
# Use servers implementing the Oblivious DoH protocol
odoh_servers = false
## Require servers defined by remote sources to satisfy specific properties
# Server must support DNS security extensions (DNSSEC)
require_dnssec = true # <-----
# Server must not log user queries (declarative)
require_nolog = true
# Server must not enforce its own blocklist (for parental control, ads blocking...)
require_nofilter = true
# Server names to avoid even if they match all criteria
disabled_server_names = []
# Connection Settings #
## Always use TCP to connect to upstream servers.
## This can be useful if you need to route everything through Tor.
## Otherwise, leave this to `false`, as it doesn't improve security
## (dnscrypt-proxy will always encrypt everything even using UDP), and can
## only increase latency.
force_tcp = false
## Enable *experimental* support for HTTP/3 (HTTP over QUIC)
## Note that, like DNSCrypt but unlike other HTTP versions, this uses
## UDP and (usually) port 443 instead of TCP.
http3 = false
## When http3 is true, always try HTTP/3 first for DoH servers.
## If the HTTP/3 connection fails, fallback to HTTP/2 and don't try
## HTTP/3 again for that server. By default, HTTP/3 is only used for
## servers that advertise support via the Alt-Svc header.
## WARNING: This setting is disabled by default because it will make
## connections significantly slower for servers that don't support HTTP/3.
## This is primarily a workaround for server operators who haven't
## configured their servers to send proper Alt-Svc headers. The better
## solution is to reach out to these operators and encourage them to
## fix their servers to correctly advertise HTTP/3 support.
http3_probe = false
## SOCKS proxy
## Uncomment the following line to route all TCP connections to a local Tor node
## Tor doesn't support UDP, so set `force_tcp` to `true` as well. When passing
## a random username and password to Tor's socks5 connection, dnscrypt-proxy gets
## an isolated circuit so it will not share an exit node with other applications.
## Note: the random username and password used by dnscrypt-proxy should not
## actually be defined in Tor's configuration.
# proxy = 'socks5://dnscrypt:dnscrypt@127.0.0.1:9050'
## HTTP/HTTPS proxy
## Only for DoH servers
# http_proxy = 'http://127.0.0.1:8888'
## How long a DNS query will wait for a response, in milliseconds.
## If you have a network with *a lot* of latency, you may need to
## increase this. Startup may be slower if you do so.
## Don't increase it too much. 10000 is the highest reasonable value.
## A timeout below 5000 is not recommended.
timeout = 5000
## Keepalive for HTTP (HTTPS, HTTP/2, HTTP/3) queries, in seconds
keepalive = 30
## Add EDNS-client-subnet information to outgoing queries
## Multiple networks can be listed; they will be randomly chosen.
## These networks don't have to match your actual networks.
# edns_client_subnet = ['0.0.0.0/0', '2001:db8::/32']
## Response for blocked queries. Options are `refused`, `hinfo` (default) or
## an IP response. To give an IP response, use the format `a:<IPv4>,aaaa:<IPv6>`.
## Using the `hinfo` option means that some responses will be lies.
## Unfortunately, the `hinfo` option appears to be required for Android 8+
# blocked_query_response = 'refused'
# Load Balancing & Performance #
## Load-balancing strategy: 'wp2' (default), 'p2', 'ph', 'p<n>', 'first', or 'random'
## 'wp2' (default): Weighted Power of Two - selects the better performing server
## from two random candidates based on real-time RTT and success rates.
## 'p2': Randomly choose 1 of the fastest 2 servers by latency.
## 'ph': Randomly choose from fastest half of servers.
## 'p<n>': Randomly choose from fastest n servers (e.g., 'p3' for fastest 3).
## 'first': Always use the fastest server.
## 'random': Randomly choose from all servers.
## The response quality still depends on the server itself.
# lb_strategy = 'wp2'
## Set to `true` to constantly try to estimate the latency of all the resolvers
## and adjust the load-balancing parameters accordingly, or to `false` to disable.
## Default is `true` that makes 'p2' `lb_strategy` work well.
# lb_estimator = true
## Set to `true` to enable hot reloading of configuration files (like allowed-names.txt,
## blocked-names.txt, etc.) when they are modified. This can increase CPU and memory usage.
## Default is `false` (hot reloading is disabled).
# enable_hot_reload = false
# Logging #
## Log level (0-6, default: 2 - 0 is very verbose, 6 only contains fatal errors)
# log_level = 2
## Log file for the application, as an alternative to sending logs to
## the standard system logging service (syslog/Windows event log).
## This file is different from other log files, and will not be
## automatically rotated by the application.
log_file = '/var/log/dnscrypt-proxy/dnscrypt-proxy.log'
## When using a log file, only keep logs from the most recent launch.
# log_file_latest = true
## Use the system logger (syslog on Unix, Event Log on Windows)
use_syslog = true
## Automatic log files rotation
# Maximum log files size in MB - Set to 0 for unlimited.
log_files_max_size = 10
# How long to keep backup files, in days
log_files_max_age = 7
# Maximum log files backups to keep (or 0 to keep all backups)
log_files_max_backups = 1
# Certificate Management #
## The maximum concurrency to reload certificates from the resolvers.
## Default is 10.
# cert_refresh_concurrency = 10
## Delay, in minutes, after which certificates are reloaded
cert_refresh_delay = 240
## Initially don't check DNSCrypt server certificates for expiration, and
## only start checking them after a first successful connection to a resolver.
## This can be useful on routers with no battery-backed clock.
# cert_ignore_timestamp = false
## DNSCrypt: Create a new, unique key for every single DNS query
## This may improve privacy but can also have a significant impact on CPU usage
## Only enable if you don't have a lot of network load
# dnscrypt_ephemeral_keys = false
## DoH: Disable TLS session tickets - increases privacy but also latency
# tls_disable_session_tickets = false
## DoH: Use TLS 1.2 and specific cipher suite instead of the server preference
## 49199 = TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
## 49195 = TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
## 52392 = TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305
## 52393 = TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305
## On non-Intel CPUs such as MIPS routers and ARM systems (Android, Raspberry Pi...),
## uncommenting the following line may improve performance.
## This may also help on Intel CPUs running 32-bit operating systems.
## However, this can cause issues fetching sources or connecting to some HTTP servers,
## and should not be set on regular CPUs.
## Keep tls_cipher_suite undefined to let the app automatically choose secure parameters.
# tls_cipher_suite = [52392, 49199]
## Log TLS key material to a file, for debugging purposes only.
## This file will contain the TLS master key, which can be used to decrypt
## all TLS traffic to/from DoH servers.
## Never ever enable except for debugging purposes with a tool such as mitmproxy.
# tls_key_log_file = '/var/log/dnscrypt-proxy/keylog.txt'
# Startup & Network #
## Bootstrap resolvers
## These are normal, non-encrypted DNS resolvers, that will be only used
## for one-shot queries when retrieving the initial resolvers list and if
## the system DNS configuration doesn't work.
## No user queries will ever be leaked through these resolvers, and they will
## not be used after IP addresses of DoH resolvers have been found (if you are
## using DoH).
## They will never be used if lists have already been cached, and if the stamps
## of the configured servers already include IP addresses (which is the case for
## most of DoH servers, and for all DNSCrypt servers and relays).
## They will not be used if the configured system DNS works, or after the
## proxy already has at least one usable secure resolver.
## Resolvers supporting DNSSEC are recommended, and, if you are using
## DoH, bootstrap resolvers should ideally be operated by a different entity
## than the DoH servers you will be using, especially if you have IPv6 enabled.
## People in China may want to use 114.114.114.114:53 here.
## Other popular options include 8.8.8.8, 9.9.9.9 and 1.1.1.1.
## If more than one resolver is specified, they will be tried in sequence.
## TL;DR: put valid standard resolver addresses here. Your actual queries will
## not be sent there. If you're using DNSCrypt or Anonymized DNS and your
## lists are up to date, these resolvers will not even be used.
bootstrap_resolvers = ['9.9.9.11:53', '8.8.8.8:53']
## When internal DNS resolution is required, for example to retrieve
## the resolvers list:
## - queries will be sent to dnscrypt-proxy itself, if it is already
## running with active servers (*)
## - or else, queries will be sent to fallback servers
## - finally, if `ignore_system_dns` is `false`, queries will be sent
## to the system DNS
## (*) this is incompatible with systemd sockets.
## `listen_addrs` must not be empty.
ignore_system_dns = true
## Maximum time (in seconds) to wait for network connectivity before
## initializing the proxy.
## Useful if the proxy is automatically started at boot, and network
## connectivity is not guaranteed to be immediately available.
## Use 0 to not test for connectivity at all (not recommended),
## and -1 to wait as much as possible.
netprobe_timeout = 60
## Address and port to try initializing a connection to, just to check
## if the network is up. It can be any address and any port, even if
## there is nothing answering these on the other side. Just don't use
## a local address, as the goal is to check for Internet connectivity.
## On Windows, a datagram with a single, nul byte will be sent, only
## when the system starts.
## On other operating systems, the connection will be initialized
## but nothing will be sent at all.
netprobe_address = '9.9.9.9:53'
## Offline mode - Do not use any remote encrypted servers.
## The proxy will remain fully functional to respond to queries that
## plugins can handle directly (forwarding, cloaking, ...)
# offline_mode = false
## Additional data to attach to outgoing queries.
## These strings will be added as TXT records to queries.
## Do not use, except on servers explicitly asking for extra data
## to be present.
## encrypted-dns-server can be configured to use this for access control
## in the [access_control] section
# query_meta = ['key1:value1', 'key2:value2', 'token:MySecretToken']
# Filters #
## Note: if you are using dnsmasq, disable the `dnssec` option in dnsmasq if you
## configure dnscrypt-proxy to do any kind of filtering (including the filters
## below and blocklists).
## You can still choose resolvers that do DNSSEC validation.
## Immediately respond to IPv6-related queries with an empty response
## This makes things faster when there is no IPv6 connectivity, but can
## also cause reliability issues with some stub resolvers.
block_ipv6 = true # <------------------
## Immediately respond to A and AAAA queries for host names without a domain name
## This also prevents "dotless domain names" from being resolved upstream.
block_unqualified = true
## Immediately respond to queries for local zones instead of leaking them to
## upstream resolvers (always causing errors or timeouts).
block_undelegated = true
## TTL for synthetic responses sent when a request has been blocked (due to
## IPv6 or blocklists).
reject_ttl = 10
# Forwarding #
## Route queries for specific domains to a dedicated set of servers
## See the `example-forwarding-rules.txt` file for an example
# forwarding_rules = '/etc/dnscrypt-proxy/forwarding-rules.txt'
# Cloaking #
## Cloaking returns a predefined address for a specific name.
## In addition to acting as a HOSTS file, it can also return the IP address
## of a different name. It will also do CNAME flattening.
## If 'cloak_ptr' is set, then PTR (reverse lookups) are enabled
## for cloaking rules that do not contain wild cards.
## See the `example-cloaking-rules.txt` file for an example
# cloaking_rules = '/etc/dnscrypt-proxy/cloaking-rules.txt'
## TTL used when serving entries in cloaking-rules.txt
# cloak_ttl = 600
# cloak_ptr = false
# DNS Cache #
## Enable a DNS cache to reduce latency and outgoing traffic
cache = true
## Cache size
cache_size = 4096
## Minimum TTL for cached entries
cache_min_ttl = 2400
## Maximum TTL for cached entries
cache_max_ttl = 86400
## Minimum TTL for negatively cached entries
cache_neg_min_ttl = 60
## Maximum TTL for negatively cached entries
cache_neg_max_ttl = 600
# Captive portal handling #
[captive_portals]
## A file that contains a set of names used by operating systems to
## check for connectivity and captive portals, along with hard-coded
## IP addresses to return.
# map_file = '/etc/dnscrypt-proxy/captive-portals.txt'
# Local DoH server #
[local_doh]
## dnscrypt-proxy can act as a local DoH server. By doing so, web browsers
## requiring a direct connection to a DoH server in order to enable some
## features will enable these, without bypassing your DNS proxy.
## Addresses that the local DoH server should listen to
# listen_addresses = ['127.0.0.1:3000']
## Path of the DoH URL. This is not a file, but the part after the hostname
## in the URL. By convention, `/dns-query` is frequently chosen.
## For each `listen_address` the complete URL to access the server will be:
## `https://<listen_address><path>` (ex: `https://127.0.0.1/dns-query`)
# path = '/dns-query'
## Certificate file and key - Note that the certificate has to be trusted.
## Can be generated using the following command:
## openssl req -x509 -nodes -newkey rsa:2048 -days 5000 -sha256 -keyout localhost.pem -out localhost.pem
## See the documentation (wiki) for more information.
# cert_file = "/var/lib/dnscrypt-proxy/localhost.pem"
# cert_key_file = "/var/lib/dnscrypt-proxy/localhost.pem"
# Query logging #
[query_log]
## Path to the query log file (absolute, or relative to the same directory as the config file)
## Can be set to /dev/stdout in order to log to the standard output.
# file = '/var/log/dnscrypt-proxy/query.log'
## Query log format (currently supported: tsv and ltsv)
format = 'tsv'
## Do not log these query types, to reduce verbosity. Keep empty to log everything.
# ignored_qtypes = ['DNSKEY', 'NS']
# Suspicious queries logging #
[nx_log]
## Log queries for nonexistent zones
## These queries can reveal the presence of malware, broken/obsolete applications,
## and devices signaling their presence to 3rd parties.
# file = '/var/log/dnscrypt-proxy/nx.log'
format = 'tsv'
# Pattern-based blocking (blocklists) #
## Blocklists are made of one pattern per line. Example of valid patterns:
## example.com
## =example.com
## *sex*
## ads.*
## ads*.example.*
## ads*.example[0-9]*.com
## Example blocklist files can be found at https://download.dnscrypt.info/blocklists/
## A script to build blocklists from public feeds can be found in the
## `utils/generate-domains-blocklists` directory of the dnscrypt-proxy source code.
[blocked_names]
## Path to the file of blocking rules (absolute, or relative to the same directory as the config file)
# blocked_names_file = '/etc/dnscrypt-proxy/blocked-names.txt'
## Optional path to a file logging blocked queries
# log_file = '/var/log/dnscrypt-proxy/blocked-names.log'
## Optional log format: tsv or ltsv (default: tsv)
# log_format = 'tsv'
# Pattern-based IP blocking (IP blocklists) #
## IP blocklists are made of one pattern per line. Example of valid patterns:
## 127.*
## fe80:abcd:*
## 192.168.1.4
[blocked_ips]
# blocked_ips_file = '/etc/dnscrypt-proxy/blocked-ips.txt'
# log_file = '/var/log/dnscrypt-proxy/blocked-ips.log'
# Pattern-based allow lists (blocklists bypass) #
## Allowlists support the same patterns as blocklists
## If a name matches an allowlist entry, the corresponding session
## will bypass names and IP filters.
## Time-based rules are also supported to make some websites only accessible at specific times of the day.
[allowed_names]
## Path to the file of allow list rules (absolute, or relative to the same directory as the config file)
# allowed_names_file = '/etc/dnscrypt-proxy/allowed-names.txt'
## Optional path to a file logging allowed queries
# log_file = '/var/log/dnscrypt-proxy/allowed-names.log'
# Pattern-based allowed IPs lists (blocklists bypass) #
## Allowed IP lists support the same patterns as IP blocklists
## If an IP response matches an allowed entry, the corresponding session
## will bypass IP filters.
[allowed_ips]
## Path to the file of allowed ip rules (absolute, or relative to the same directory as the config file)
# allowed_ips_file = '/etc/dnscrypt-proxy/allowed-ips.txt'
# log_file = '/var/log/dnscrypt-proxy/allowed-ips.log'
# Time access restrictions #
## One or more weekly schedules can be defined here.
## Patterns in the name-based blocked_names file can optionally be followed with @schedule_name
## to apply the pattern 'schedule_name' only when it matches a time range of that schedule.
## For example, the following rule in a blocklist file:
## *.youtube.* @time-to-sleep
## would block access to YouTube during the times defined by the 'time-to-sleep' schedule.
## {after='21:00', before= '7:00'} matches 0:00-7:00 and 21:00-0:00
## {after= '9:00', before='18:00'} matches 9:00-18:00
[schedules]
# [schedules.time-to-sleep]
# mon = [{after='21:00', before='7:00'}]
# tue = [{after='21:00', before='7:00'}]
# wed = [{after='21:00', before='7:00'}]
# thu = [{after='21:00', before='7:00'}]
# fri = [{after='23:00', before='7:00'}]
# sat = [{after='23:00', before='7:00'}]
# sun = [{after='21:00', before='7:00'}]
# [schedules.work]
# mon = [{after='9:00', before='18:00'}]
# tue = [{after='9:00', before='18:00'}]
# wed = [{after='9:00', before='18:00'}]
# thu = [{after='9:00', before='18:00'}]
# fri = [{after='9:00', before='17:00'}]
# Servers #
## Remote lists of available servers
## Multiple sources can be used simultaneously, but every source
## requires a dedicated cache file.
## Refer to the documentation for URLs of public sources.
## A prefix can be prepended to server names in order to
## avoid collisions if different sources share the same for
## different servers. In that case, names listed in `server_names`
## must include the prefixes.
## If the `urls` property is missing, cache files and valid signatures
## must already be present. This doesn't prevent these cache files from
## expiring after `refresh_delay` hours.
## `refreshed_delay` must be in the [24..168] interval.
## The minimum delay of 24 hours (1 day) avoids unnecessary requests to servers.
## The maximum delay of 168 hours (1 week) ensures cache freshness.
[sources]
### An example of a remote source from https://github.com/DNSCrypt/dnscrypt-resolvers
[sources.public-resolvers]
urls = [
'https://raw.githubusercontent.com/DNSCrypt/dnscrypt-resolvers/master/v3/public-resolvers.md',
'https://download.dnscrypt.info/resolvers-list/v3/public-resolvers.md',
cache_file = '/var/cache/dnscrypt-proxy/public-resolvers.md'
minisign_key = 'RWQf6LRCGA9i53mlYecO4IzT51TGPpvWucNSCh1CBM0QTaLn73Y7GFO3'
refresh_delay = 73
prefix = ''
### Anonymized DNS relays
[sources.relays]
urls = [
'https://raw.githubusercontent.com/DNSCrypt/dnscrypt-resolvers/master/v3/relays.md',
'https://download.dnscrypt.info/resolvers-list/v3/relays.md',
cache_file = '/var/cache/dnscrypt-proxy/relays.md'
refresh_delay = 73
prefix = ''
### ODoH (Oblivious DoH) servers and relays
# [sources.odoh-servers]
# urls = ['https://raw.githubusercontent.com/DNSCrypt/dnscrypt-resolvers/master/v3/odoh-servers.md', 'https://download.dnscrypt.info/resolvers-list/v3/odoh-servers.md']
# cache_file = '/var/cache/dnscrypt-proxy/odoh-servers.md'
# minisign_key = 'RWQf6LRCGA9i53mlYecO4IzT51TGPpvWucNSCh1CBM0QTaLn73Y7GFO3'
# refresh_delay = 73
# prefix = ''
# [sources.odoh-relays]
# urls = ['https://raw.githubusercontent.com/DNSCrypt/dnscrypt-resolvers/master/v3/odoh-relays.md', 'https://download.dnscrypt.info/resolvers-list/v3/odoh-relays.md']
# cache_file = '/var/cache/dnscrypt-proxy/odoh-relays.md'
# prefix = ''
### Quad9
# [sources.quad9-resolvers]
# urls = ['https://www.quad9.net/quad9-resolvers.md']
# minisign_key = 'RWQBphd2+f6eiAqBsvDZEBXBGHQBJfeG6G+wJPPKxCZMoEQYpmoysKUN'
# cache_file = '/var/cache/dnscrypt-proxy/quad9-resolvers.md'
# prefix = 'quad9-'
### Another example source, with resolvers censoring some websites not appropriate for children
### This is a subset of the `public-resolvers` list, so enabling both is useless.
# [sources.parental-control]
# urls = ['https://raw.githubusercontent.com/DNSCrypt/dnscrypt-resolvers/master/v3/parental-control.md', 'https://download.dnscrypt.info/resolvers-list/v3/parental-control.md']
# cache_file = '/var/cache/dnscrypt-proxy/parental-control.md'
### dnscry.pt servers - See https://www.dnscry.pt
# [sources.dnscry-pt-resolvers]
# urls = ["https://www.dnscry.pt/resolvers.md"]
# minisign_key = "RWQM31Nwkqh01x88SvrBL8djp1NH56Rb4mKLHz16K7qsXgEomnDv6ziQ"
# cache_file = "dnscry.pt-resolvers.md"
# prefix = "dnscry.pt-"
# Servers with known bugs #
[broken_implementations]
## Cisco servers currently cannot handle queries larger than 1472 bytes, and don't
## truncate responses larger than questions as expected by the DNSCrypt protocol.
## This prevents large responses from being received over UDP and over relays.
## Older versions of the `dnsdist` server software had a bug with queries larger
## than 1500 bytes. This is fixed since `dnsdist` version 1.5.0, but
## some server may still run an outdated version.
## The list below enables workarounds to make non-relayed usage more reliable
## until the servers are fixed.
fragments_blocked = [
'cisco',
'cisco-ipv6',
'cisco-familyshield',
'cisco-familyshield-ipv6',
'cisco-sandbox',
'cleanbrowsing-adult',
'cleanbrowsing-adult-ipv6',
'cleanbrowsing-family',
'cleanbrowsing-family-ipv6',
'cleanbrowsing-security',
'cleanbrowsing-security-ipv6',
# Certificate-based client authentication for DoH #
[doh_client_x509_auth]
## Use a X509 certificate to authenticate yourself when connecting to DoH servers.
## This is only useful if you are operating your own, private DoH server(s).
## 'creds' maps servers to certificates, and supports multiple entries.
## If you are not using the standard root CA, an optional "root_ca"
## property set to the path to a root CRT file can be added to a server entry.
# creds = [
# { server_name='*', client_cert='client.crt', client_key='client.key' }
# Anonymized DNS #
[anonymized_dns]
## Routes are indirect ways to reach DNSCrypt servers.
## A route maps a server name ("server_name") to one or more relays that will be
## used to connect to that server.
## A relay can be specified as a DNS Stamp (either a relay stamp, or a
## DNSCrypt stamp) or a server name.
## The following example routes "example-server-1" via `anon-example-1` or `anon-example-2`,
## and "example-server-2" via the relay whose relay DNS stamp is
## "sdns://gRIxMzcuNzQuMjIzLjIzNDo0NDM".
## !!! THESE ARE JUST EXAMPLES !!!
## Review the list of available relays from the "relays.md" file, and, for each
## server you want to use, define the relays you want connections to go through.
## Carefully choose relays and servers so that they are run by different entities.
## "server_name" can also be set to "*" to define a default route, for all servers:
## { server_name='*', via=['anon-example-1', 'anon-example-2'] }
## If a route is ["*"], the proxy automatically picks a relay on a distinct network.
## { server_name='*', via=['*'] } is also an option, but is likely to be suboptimal.
## Manual selection is always recommended over automatic selection, so that you can
## select (relay,server) pairs that work well and fit your own criteria (close by or
## in different countries, operated by different entities, on distinct ISPs...)
# routes = [
# { server_name='example-server-1', via=['anon-example-1', 'anon-example-2'] },
# { server_name='example-server-2', via=['sdns://gRIxMzcuNzQuMjIzLjIzNDo0NDM'] }
## Skip resolvers incompatible with anonymization instead of using them directly
skip_incompatible = false
## If public server certificates for a non-conformant server cannot be
## retrieved via a relay, try getting them directly. Actual queries
## will then always go through relays.
# direct_cert_fallback = false
# DNS64 #
[dns64]
## DNS64 is a mechanism for synthesizing AAAA records from A records.
## It is used with an IPv6/IPv4 translator to enable client-server
## communication between an IPv6-only client and an IPv4-only server,
## without requiring any changes to either the IPv6 or the IPv4 node,
## for the class of applications that work through NATs.
## There are two options to synthesize such records:
## Option 1: Using a set of static IPv6 prefixes;
## Option 2: By discovering the IPv6 prefix from DNS64-enabled resolver.
## If both options are configured - only static prefixes are used.
## (Ref. RFC6147, RFC6052, RFC7050)
## Do not enable unless you know what DNS64 is and why you need it, or else
## you won't be able to connect to anything at all.
## Static prefix(es) as Pref64::/n CIDRs
# prefix = ['64:ff9b::/96']
## DNS64-enabled resolver(s) to discover Pref64::/n CIDRs
## These resolvers are used to query for Well-Known IPv4-only Name (WKN) "ipv4only.arpa." to discover only.
## Set with your ISP's resolvers in case of custom prefixes (other than Well-Known Prefix 64:ff9b::/96).
## IMPORTANT: Default resolvers listed below support Well-Known Prefix 64:ff9b::/96 only.
# resolver = ['[2606:4700:4700::64]:53', '[2001:4860:4860::64]:53']
# Monitoring UI #
[monitoring_ui]
## Enable the monitoring UI
enabled = false
## Listen address for the monitoring UI
listen_address = "127.0.0.1:8080"
## Optional username and password for basic authentication
## To disable authentication, set username to an empty string: username = ""
## If both username and password are empty, no authentication is required
username = "admin"
password = "changeme"
## Optional TLS certificate and key for HTTPS
## If both are empty, HTTP will be used
tls_certificate = ""
tls_key = ""
## Enable query logging in the monitoring UI
## This will show recent queries in the UI
enable_query_log = true
## Privacy level for the monitoring UI
## 0: show all details including client IPs
## 1: anonymize client IPs (default)
## 2: aggregate data only (no individual queries or domains shown)
privacy_level = 1
## Maximum number of recent query log entries to keep in memory
## Helps control memory usage on high-traffic servers
## Default: 100
# max_query_log_entries = 100
## Maximum memory usage in MB for recent query logs
## Automatic cleanup when limit is exceeded
## Default: 1
# max_memory_mb = 1
## Enable Prometheus metrics endpoint
## Default: false
# prometheus_enabled = false
## Path for Prometheus metrics endpoint
## Default: /metrics
# prometheus_path = "/metrics"
# Static entries #
[static]
## Optional, local, static list of additional servers
## Mostly useful for testing your own servers.
# [static.myserver]
# stamp = 'sdns://AQcAAAAAAAAAAAAQMi5kbnNjcnlwdC1jZXJ0Lg'
