I’ve tried several times to create a Samba Share. But unfortunately failed all the time. As I don’t know much about networking, I can’t find out where is the problem.
Today I tried to create a SMB share but this time unlucky too. Here how I configured my profile:
Step 1: creating smb.conf
Inside /etc/samba/ I’ve created a smb.conf file as follows:
[global]
server string = File Server
workgroup = MEDIA
security = user
map to guest = Bad User
name resolve order = bcast host
include = /etc/samba/share.conf
and the share.conf like this:
[Public Files]
path = /home/myUserName/Public/SMB_Public
force user = smbuser
force group = smbgroup
create mask = 0664
force create mode = 0664
directory mask = 0775
force directory mode = 0775
public = yes
writable = no
Step 2: creating user & user group
After that I created a user group as
sudo groupadd --system smbgroup
then created a user with:
sudo useradd --system --no-create-home -g smbgroup -s /bin/false smbuser
Step 3: creating shared folder and giving permissions
Then I created the share folder which is in my case ~/Public/SMB_Public
mkdir ~/Public/SMB_Public
sudo chown -R smbuser:smbgroup ~/Public/SMB_Public
sudo chmod -R g+w ~/Public/SMB_Public
*Step 4: Restarting smb.service
Now I restarted smb.service
sudo systemctl restart smb.service
The output of tesparm is:
❯ testparm
Load smb config files from /etc/samba/smb.conf
Loaded services file OK.
Weak crypto is allowed
Server role: ROLE_STANDALONE
Press enter to see a dump of your service definitions
# Global parameters
[global]
security = USER
workgroup = MEDIA
idmap config * : backend = tdb
[Public Files]
create mask = 0664
guest ok = Yes
Everything seems to be OK. This shared folder is visible in my android phone(SMB). But can’t access with guest account. Where to change? I really don’t understand where is the problem.
